They run better on diesel
   / They run better on diesel #1
Elkins45
KY
Kubota L3800
Just a little tip. If you own a diesel tractor with a drain at the bottom of the filter housing, occasionally open it up and let a few drops out. I started my MF 245 this weekend for the first time since the fall. It started and ran great for a few minutes but started losing power and smoking, then eventually died. I could crank it and get it to run for a few seconds if I waited a few minutes between attempts.
Long story short, there was about a pint of water in the fuel system. I opened the drain below the filter and let it drip for 10-12 minutes before something that wasn't obviously plain water started dripping out. Not surprisingly it ran like a champ after that.
Jus something to think about if your tractor isn't running like you know it should.
   / They run better on diesel #2
Also if you fill before storeing,it helps keep the moisture down.I Power Service all my fuel also,I think it helps.
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
UNUSED PABREAK METAL COYOTE SHOOTING TARGET (A57193)
UNUSED PABREAK...
(APPROX 125) UNUSED TRAFFIC CONES (A57193)
(APPROX 125)...
(8) 12" CHANNEL IRON (A57192)
(8) 12" CHANNEL...
2021 Caterpillar 304E2 (A53317)
2021 Caterpillar...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
