dapper
- Joined
- Nov 17, 2005
- Messages
- 284
- Location
- S.W. Ohio
- Tractor
- NH TN-65, Ford/NH 3430, Ford/NH 3930, Kubota zd21
Evening all. Looking for some information on a thermostat/glow plug. This is on a 96 NH 3430. Book calls it a thermostat I believe. Parts listing says it is an "Intake Manifold Heater". It is more of a glow plug in the manifold which should get hot, ignite the fuel, (has its own fuel line) and heat the incoming air. Should then fire right up. Book says so!!!! Couldn't be wrong
Mine has not worked since I purchased the tractor, so I thought now that warm weather was here, and I don't need it, I would repair, or replace the unit.
First checked fuse. 25a. Checks good. Checked that there was voltage when key was turned. Good 12v. Ok me thinks, must be bad thermostat plug unit. So off to the blue dealer I gets, and 25$ later I am home, shiny new thermostat in hand. Shouldn't be to bad, just 2 wrenches?. yea right,
and it turns out that taking the battery bracket off is not all that hard after all?.
Any way, out with the old, in with the new. Done! Checked fuse, and voltage, and still all good. Turned the key and waited the recommended 15 seconds, and then felt the manifold, and thermostat, and no heat. Cool as before. Fired tractor, thinking maybe it did not have fuel getting to plug.Tractor started and ran fine. Shut off, and tried the 15 sec thing again, and still no heat. I am convinced it still isn't working.
Could be a out of the box failure, but since I have the same symptoms as the original, I am inclined to believe that it is more likely that there something I'm missing.
Hoping that some of the experience on here may have a thought to try. Other than parking it inside to keep it toasty, I don't know what else I might try. Any suggestions?
Thanks for listening.
