The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!!
   / The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #71
I have a jd 4066r, just wondering if you think my tractor is well suited for this new utility grapple. Or should i go a step down to their other grapple. Thank you in advance
   / The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #72
Your tractor is slightly more powerful than my own, but in the same class. I have the original grapple at 72" wide. I would be pleased with the version 2.0 of that same grapple as the updated version opens a little wider, and for my use, popping aspen rootballs out of sphagnum the length of the tines still allows me good leverage. That said, that bigger version allows larger bites of lighter material like brush.
   / The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #73
Thanks eric..awesome videos on youtube btw
   / The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #74
So thats not the utility grapple right?
   / The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #75
What I have is the original dual lid wicked root grapple. For the kind of material I'm processing, which is stumps stuck into sphagnum and endless deadfalls, I'd get the version 2.0 of the same grapple. The new utility grapple allows for nabbing more material in one bite. Also, I find myself hand loading the grapple with junk. The new utility grapple allows much more junk to get hand loaded.
It really comes down to what you're going to use the grapple for. Lighter material or lift capability to burn? Get the new utility grapple.
Good advice from Eric.
The NX6010 and JD4066 tractors are both large compact tractors with similar weights and the loader lift capacities are over 2,500 pounds.
I don't think you can really go wrong with either grapple.
Click this for the full comparison chart.
   / The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #77
I would really like the extra strength in the utility grapple...is there really a negative to it?
   / The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #78
I really like the bigger opening of 42 1/2". My HD 84" grapple only has 34" opening.
My favorite Wicked Utility Grapple is this 55" model. It looks MEAN.
Travis
   / The WICKED GRAPPLE for UTILITY TRACTORS!!!!!!! #80
Yeah i think ill be getting the utility grapple 55...cant wait...ill be calling you guys soon..just need to find out what coupler size for my jd4066r and buy the kit to bring the hoses from the back to the front grom my third valve
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
JOHN DEERE CX15 BATWING ROTARY CUTTER (A52708)
JOHN DEERE CX15...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
2007 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2007 Chevrolet...
CHAMPION OUTBOARD MOTOR (A58374)
CHAMPION OUTBOARD...
