The Log house Project begins........
   / The Log house Project begins........
Thanks Chad!...still a lot of work to be done. These kitchen cabinet doors(fitting the tin into each one) are really time consuming...two hands are not enough and I'm not sure if an octopus could get this done any faster. Pic's to follow......
   / The Log house Project begins........ #1,592
Congratulations on your success!!!! Love that you get to live in it now and that you did so well on your loan!!!
That inside railing is very impressive. Thanks for all the pictures and describing what you are doing. I'm inspired by your work and I've learned a lot from seeing how you do things. Especially working with cedar, which is something that I like to work with too.
As for Bosch, I consider them to be about as good as it gets in tools. I try to stock up on bits for my driver and blades when I go to Lowes because they are the only ones who sell Bosch. By far the best out there!!!!
Eddie
Thanks Eddie...the cedar work is fun and satisfying!
I did cheap out a bit and bought a used Bosh 1587avs on fleabay for $60. It arrived a few days ago and wow, what a difference. It actually cuts straight, smooth with zero vibration.....I should have bought one years ago:cool:
Cabinet door update...I have them all done. After planing down the cherry to 3/4" I ripped it to 2.5"'s, then cut out each frame:
Then I cut a 3/16" deep kerf in them to receive the tin:
At each corner is a #10 biscuit slot:
Then I measured out each frame and cut the panel 1/4" all the way around larger:
The I learned something(the hard way), when cutting the tin, the left side always curls up a bit causing a wave on the edge. This was causing all my "issues" when fitting the tin, so I started turning the tin to keep the panel to the right...no curl:
And better yet, the tin snips I am using were my Granfathers, they are Crescent made in USA.
Then the cut out panels went into the paint shop:
From the paint shop to the glue and clamp shop:
The final product after a couple coats of Waterlox:
I have to say it would be a toss up between my favorite wood....Cherry or Walnut...both are simply beautiful..............
   / The Log house Project begins........ #1,598
Rick,
You need a set of Aviation Snips....one pair for left and one pair for right cuts. There is a pair that cuts neutral, but I never use them.
hugs, Brandi
Rick,
hugs, Brandi
mmmmHmmm....NOW you tell me:laughing:
   / The Log house Project begins........ #1,600
Maybe the spray hose back into the well is to let oxygen clean the water??? The fact that whenever you are running the water it is continuously recharging some of the water in the well???
I've always wanted a polished copper counter like in a fancy bar, except I don't want to have to polish it. I hope yours stand up to abuse.
My water also smelled of sulfur. I installed an air injector in the well line before the tank and it takes care of it. My well man told me to try it. Cheap and effective.
http://www.ohiopurewater.com/shop/files/ClackPVCnotes.pdf
The only draeback to this setup is the eventual buildup of air in your storage tank. You'll have to drain it once in a while.
1612 (A58375)
1612 (A58375)
TANK MANIFOLD (A55745)
Ford 8510 (A53317)
Ford 8510 (A53317)
LOT: (10) Wheel Loader Bucket Teeth (A59076)
LOT: (10) Wheel...
2263 (A58376)
2263 (A58376)
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
