Terrible front-end loader screeching noise
   / Terrible front-end loader screeching noise #1
beppington
Elite Member
of my
Here
I greased everything I could find, every zerk fitting, etc ... then realized the one thing left: The bucket level indicator rod. Man, that thing was making an awful screeching.
Hard to zone in on it when you're by yourself trying to operate the loader valve & also get your ears close to a sound, all while the diesel's running.
Anyway, dabbed a little grease on that rod & all screeching is now gone!! :thumbsup:
Now, if I could just remember to clean the radiator screen more often, to keep the engine from overheating :(
   / Terrible front-end loader screeching noise #2
As Originally Posted by PA hayseed
You may need to spray that rod every once in awhile, kinda a metal on metal issue. Mine has a squeal detector on it, when it starts to squeal when I curl the bucket it means it is time to lubricate it again. A little wd40 or other spray lubricant will work just fine.
On the thread Stupid Question - What is that rod on the loader? - Page 3 - TractorByNet.com
   / Terrible front-end loader screeching noise #3
Just after greasing my front loader , I picked up and curled my bucket and heard that same screeching noise you were talking about . I thought it was coming from the Hyds to my loader. I'll try the wd-40 trick on my indicator rod tomorrow to see if that 's it.
That's one thing you can count on , if you have a problem you can bet someone has had it before you and can tell you just what to try to fix it.:thumbsup: Thanks again for all the input.:D
   / Terrible front-end loader screeching noise #4
If you want something that will stop the squealing for a long time, spray some chain wax on the rod and where it slides. It is for lubing motorcycle chains, but it leaves a wax film that is near impossible to get off. It has lasted for over a year without making the noise again!
Joel
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
Target Ecoline Walk behind concrete saw (A49461)
Target Ecoline...
McCullough FG600MK Generator (A50860)
McCullough FG600MK...
2001 International 3800 4X2 School Bus (A50860)
2001 International...
Diesel Fuel Tank (A50860)
Diesel Fuel Tank...
2017 Rogator RG1300B Dry Fertilizer Applicator (A51039)
2017 Rogator...
