Loader Tc33da hydraulic noise
   / Tc33da hydraulic noise #1
Justin259
New holland Tc33da
I have a 2005 NH Tc33da that has recently started to make a loud whine when raising the loader and bucket curl up. I have checked fluid level and replaced the filter, not to sure where to look from here any help would be great thanks!
   / Tc33da hydraulic noise #2
Have you owed this tractor for a while? Are you in a cold region?
I have owned it about 5 years now, 700 hours on it now, iv always kept up on filter and fluid changes. Yes I am in a upstate NY but iv ran it year round the whole time iv had it and never ran into this
   / Tc33da hydraulic noise #4
Double check the shut/off for the hydraulics. On my tc33d, it was on the right side (under your right foot), on a gray block, where all the steel hyd pipes are coming out for the loader. Amongst the pipes, there is a place for a flat heat screwdriver. One way is off, the other way is on.
I did not know about that shut off I will check that first, i am getting a ton of vibration on the line coming from the cooler to the filter housing
   / Tc33da hydraulic noise #6
You can switch that while it is running too while you try the loader.
I could not find the shut off for the hydraulics, I did notice it is making the same noise when raising the 3point so I ended up taking the loader off to get a better view of the pump area
   / Tc33da hydraulic noise #9
What did you find out on this? Plugged or restricted line (bent, etc)?
I haven’t gotten it fixed yet, took the pump off and apart that all looks good going to start looking for a restriction somewhere
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
Set of AG R4 Wheels and Tires (A51039)
Set of AG R4...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A51039)
2018 Dodge Ram...
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
