Spencer
Veteran Member
- Joined
- Jan 2, 2002
- Messages
- 1,267
- Location
- Western Michigan
- Tractor
- NH TC33D w/R4 Tires, Rear Remote, Hydraulic Toplink, 2 Auxiliary Work Lights, 7308 Loader w/Kasco Uni-Hitch (Quick Tach)
Here are a few pics of my two new auxilary lights that I mounted on my TC33D. I tapped into the existing wiring harness that is specifically for rear work lights. I used brackets right from NH that are specifically made for these auxilary lights. You just unbolt the rear flasher lights and place the bracket between the rear flasher bracket and the ROPS. The brackets were about 16 bucks a piece from my dealer. The lights are from J.W. Speaker Corporation and sold as Speaker agri-brite. They both are 4" x 6", 12 Volt, 4 Amp halogen flood lights. They have a watertight switch built right into them. They were 26 bucks a piece from my dealer. The wiring harness that NH provides is on a 15 amp fuse. I didn't blow that fuse, but the first time I went to start up the tractor after the installation I forgot to turn off all my lights. I had on both auxilary lights, the front headlights, and the rear tail lights. After the glow plugs turned off I went to turn the switch further to engage the starter and thats when my main 30 amp fuse blew. I now have some spares in the toolbox on the tractor. I will always make sure all lights are off when starting the tractor from now on.
First picture is a full view showing both lights.
Spence
Spence
