Tires TC24D rear R4 tires rubbing on lower arms, damaged
   / TC24D rear R4 tires rubbing on lower arms, damaged #11
Traci is right: the PTO brake will not allow you to turn the PTO by hand (or screwdriver) on the TC40D. You have to move the mower end of things. I bought an overriding clutch for my chipper and leave it on all the time now. It sure makes hooking up easier even though it overrides the safety aspect of the PTO brake. Overriding clutch is roughly $50 at Tractor Supply.
   / TC24D rear R4 tires rubbing on lower arms, damaged #12
Guess I don't have one of them /forums/images/graemlins/crazy.gif
   / TC24D rear R4 tires rubbing on lower arms, damaged #13
You may want to check your manual, mine say's that rear R4 tires can only be dished out. Most of my 3pt equipment seem to place the arms really close to the tires, if the tires were dished in, I'm sure they might rub on the 3pt attachment.
   / TC24D rear R4 tires rubbing on lower arms, damaged #14
VaTractorGirl, I must admit that turning the hitch pins to the center was not my idea. I learned that trick right here on TBN from someone else /forums/images/graemlins/smile.gif. As far as stability, I have not had any problems. Sorry to say, the hooking up part stays the same /forums/images/graemlins/frown.gif.
   / TC24D rear R4 tires rubbing on lower arms, damaged #15
</font><font color="blue" class="small">( Guess I don't have one of them )</font>
You're lucky you don't. I guess the PTO brake is for safety, but it sure makes it a pain to hook up to the PTO unless you can move the implement or it happens to line up perfectly.
Mark
2023 Kubota L6060HST Compact Utility Tractor (A56438)
2023 Kubota...
2021 Kubota SVL75-2 Track Loader (A56436)
2021 Kubota...
1993 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
1993 Ford F-250...
JRB 54" QUICK ATTACH HANG ON WHEEL LOADER FORKS (A52709)
JRB 54" QUICK...
New/Unused CFG Industrial NT18K Mini Excavator (A57453)
New/Unused CFG...
2006 Yamaha Grizzly 125 2x4 Utility ATV (A59225)
2006 Yamaha...
