spitter
Platinum Member
My TC 45D Has the sticky pedal syndrome. I have set everything as per the shop manuals specks. I run it over 2k rpms. and still the pedals don't return to center. As per the shop manual it says to look for things in a bind which I am it the process of doing. The other thing it says to do is to check the HST damper question is how to check it? Do they mean leaks of is there some kind of test to run.
Also, I've heard there is an upgraded return to center spring on the DA's, but Messics has the D's and DA's spring listed as the same part number. At $45 dollars I would like to know if there is at least a difference in the spring that I already have. The damper is $350 so I don't want to just buy it until I know that mine is no good.
