Swivel on a Rear blade
   / Swivel on a Rear blade #1
VroomVroom
Platinum Member
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
Hello, I was wondering if someone could tell me more about whats used as the swivel on a rear blade. I have some steel, and even an older blade off of a 1940s tractor that I would going to make into a rear blade as I need one this summer. I could come up with various ways of making a swivel...but I was wondering what the actual manufactured rear blades use to swivel? I've never looked at one. I see some pictures on here where it looks nothing more then a 3/4 inch threaded bolt. And how long is it normally. Thanks.
   / Swivel on a Rear blade #2
   / Swivel on a Rear blade #3
Definitely not 3/4" for the shaft. More like 3 or 4"
Im in the process of designing a smaller version of this (below) and will be using 3" for the shafts and 1/2" (likely 3/4") for the rotation plates.
   / Swivel on a Rear blade #4
Nice setup, I did something similar about 25 years ago with a 10' all hydraulic rearblade. Added a set of combine rear wheels that folded up out of the way and added weight to the blade or all the way down to use as guage wheels. Wish I had that setup to use now, pulled it with a Case 1370 tractor.
   / Swivel on a Rear blade #5
I just went out and looked at my 6' cat 1 rear blade. It has a 4" OD tubing welded to the structure that hooks to the tractor, with a smaller tubing inside that is fastened to the blade assy and the top plate which rotates with the blade. The pin which goes in one of several holes is 1".
   / Swivel on a Rear blade #6
I have a fair bit of driveway to maintain... several times a year, so I hope a grader setup like that will help.. I was going to buy an off the shelf rear blade, but none I found were heavy enough for my liking.
   / Swivel on a Rear blade #7
I think you might be money ahead with a small landplane for driveway maintenance. I built this one last year for my x749 and should be just right for a BX25.
Ok, thats a big help actually. Tubing. I was thinking of an old axle out of a pickup. Maybe get one end partially threaded...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
2019 Chevrolet Tahoe SUV (A48082)
2019 Chevrolet...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
2011 Ford Flex SUV (A50860)
2011 Ford Flex SUV...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
