Swapped Out FEL Valve, Got Grapple Control and FREE Rear Remotes
   / Swapped Out FEL Valve, Got Grapple Control and FREE Rear Remotes
That's a great point. I could build a small mount adjacent to the existing control valve. What was the reason you did not add a single double action valve?
I did end up getting my rear remote hydraulics installed once mahindra sent me the right parts. Simple install after all. On a side note, did you know Moes in West Chester is closing up on the first of Feb?
I knew I wanted to install rear remotes, and with "top'n'tilt", having a joystick valve (the former FEL controller) would be very intuitive, so I used the new valve for the FEL.
   / Swapped Out FEL Valve, Got Grapple Control and FREE Rear Remotes #12
I read this thread with interest - I'd been considering the same valve for my Kioti DS3510. I damaged the original joystick, but cobbled a repair. I wanted to add a grapple, and avoid a button. I hesitated because of the sensitivity, but gained confidence from your post. The valve has arrived, and I've plotted a mount. I will get to fabbing right after Christmas (been too short of time and energy to get started) as I'm off until January 8.
Thank you for sharing your experience.
Finally got well enough to get 'er done!
Works great, much better than the factory joystick.
Gee, I completely missed the part about Moe's. That was 2.5 miles from my house ... now the closest dealer is nearly an hour. Apparently they were bought out by a big group that owns a bunch of Ace hardware stores, and they don't want to deal with the tractors. Had I known that, I'd maybe be a Mahindra dealer now, it is time for another career change!
   / Swapped Out FEL Valve, Got Grapple Control and FREE Rear Remotes #14
I just purchased one of those valves and was wondering if you could tell me what size and type fitting were required. My Kioti loader is using 3/8 lines. Thanks
   / Swapped Out FEL Valve, Got Grapple Control and FREE Rear Remotes #15
I cheated. I took the tractor and the new valve to the hydraulic shop. The helpful folks there hooked me up with all the fittings I needed to adapt to the new valve, and made up the hoses where I needed them. I lacked the knowledge and experience to do it myself, and it's 35 miles each way if I missed something. They even had the Power Beyond adapter in stock. I also bought the sleeve material for the new hoses.
I reused the original quick connects, and added four more sets for the new third function lines. The supply, PB and return ports are SAE 12, the valve ports are SAE 10, IIRC.
   / Swapped Out FEL Valve, Got Grapple Control and FREE Rear Remotes #16
Thanks for your response. I haven't pulled mine apart, but I am guessing the SAE 10 and 12 ports for the valve have O rings? I was hoping to get adapters to adapt the 3/8 fitting I have now. Course I still have to buy the other 2 that are extra. I now have the 2 spool Prince LVR and want to adapt the ones I now have which are SAE 8 and 10.
   / Swapped Out FEL Valve, Got Grapple Control and FREE Rear Remotes #17
Yes, they have O rings. (Get extras - that was an extra trip!)
   / Swapped Out FEL Valve, Got Grapple Control and FREE Rear Remotes #18
Thanks Teachu2
(APPROX.52) UNUSED 2X4X16 PRIME GRADE LUMBER (A57192)
(APPROX.52) UNUSED...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 HOOPER TRAILERS INC. (A57192)
2020 HOOPER...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
Alligator Statue (A55853)
Alligator Statue...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
