Survey
   / Survey #11
This stuff:
   / Survey #12
The cheapest stuff TSC sells. Bought a case 9 months ago while it was on sale. I think im down to 5 tubes. I would go broke buying $10 a tube grease. Becids most of the stuff thats going to wear out on things like a loader are low speed and in the dirt. Grease is grease at that point.
Things like wheel bearings, mower bearings or other tight clearance items i would use better grease.
   / Survey #13
Well, 5 bux per tube for mine, so...win. :D
   / Survey #14
I switched to Amalie Pro Tac+ with 5% Moly Grease for my backhoe. Black, thick, nasty stuff that seems to last longer than the of the shelf stuff I was buying.
   / Survey #15
Amalie Pro Tac+ and the Valvoline Cerulean, need to review them and check the reviews.
Will give me another Grease to add to the list.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2024 TOFT 1550 Hydraulic Breaker (A50860)
2024 TOFT 1550...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
