Suggestions for a Hydraulic Top Link for a CK30
   / Suggestions for a Hydraulic Top Link for a CK30 #11
Thank you all for the suggestions etc. I do have a single remote in the back, how hard and $ is it to double that up? Is there a controlled diverted I could hang off the single that would be relatively inexpensive and give me 2 sets (thinking top-n-tilt)?
Thanks
Yes Kioti does. I believe the part number for the second rear remote kit is 322027. This is the second kit with the Float feature. Prices I got were in the mid $300 to high $400 range. Check with your dealer. I got mine out of California at an excellent price. (Search my thread on adding a second remote to my Bobcat)
   / Suggestions for a Hydraulic Top Link for a CK30 #12
Agristore has some nice top links at a good price. Agristore USA | Replacement Parts | Hydraulic Top Links I got one for a Bobcat CT235 from them. Get the one that matches your OEM top link dimensions. Measure it collapsed and extended.
He does not want to match his OEM top link working length with the Pat's QH that add 3 3/4" to the length of his draft arms. To the best of my knowledge, none of the cat 1 Agristore units are actually long enough. The longest unit Part Number 06004 would work fine for the most part though.
   / Suggestions for a Hydraulic Top Link for a CK30 #13
Thanks
A nice diverter kit runs about $700. Get the 2nd factory valve with the float function, less money and waaaaay cleaner install. :thumbsup:
2016 Ford F-350 Super Duty Pickup Truck, VIN: 1FT8W3DT1GEB84319, Crew Cab, 4x4, Steel Flatbed (A59076)
2016 Ford F-350...
200 Gallon Tank (A57148)
200 Gallon Tank...
2013 CATERPILLAR 336E L (A58216)
2013 CATERPILLAR...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
35176 (A55758)
35176 (A55758)
Behringer 19 high x 43 wide Metal-Cutting Bandsaw (A59213)
Behringer 19 high...
