sudden engine stop B2650
   / sudden engine stop B2650 #11
If original battery, try boosting it, or remove battery and have it “load tested” at any garage…
However my guess is a battery cable, especially the ground cable. Remove both ends and clean post and frame with sandpaper. When reattaching apply dielectric grease at each end and then fasten securely. Keep us posted…
i came to a dead end as i am not a mechanic...i have a service company coming this week. Fingers crossed. I also don't think it can be towed??? Maybe a short pull on a flatbed if they need to bring it to the shop Thanks for all the suggestions and you are right...i have had very few problems with this machine.
Battery is fine...all lights , heater, ac work fine. I checked the connections, all clean and tight. Im convinced it is electrical and a breaker or fuse.
update... my tractor has Operator Presence Control system (OPC) in other words safety shut offs. Anyhow, that 5 amp fuse was blown for that system....and it blew after applying the parking brake. Have not gone looking yet for where a wire is being scuffed or what is causing the fuse to go out but it has something to do with setting the brake and not a general wiring problem. More later
2014 John Deere 635F Grain Platform (A50657)
2014 John Deere...
UNUSED Stainless Steel Sink (A50860)
UNUSED Stainless...
2014 Chevrolet Impala Limited Sedan (A48082)
2014 Chevrolet...
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
2003 John Deere 1790 Planter (A50657)
2003 John Deere...
