Snow Blade Subframe for the Kubota M9000 front blade?
   / Subframe for the Kubota M9000 front blade? #1
ArtMech
Platinum Member
Lithuania, EU
Present: 2003 Kubota M9000 DTF; 2001 Kubota B72. Sold: 1985 Kubota L2202
Hi fellows,
Is anybody able to consult me, what kind of subframe should tractor (in this case M9000) be equipped with to attach a front blade? The Operator's Manual says concerning the front blade: "Need subframe". But what a subframe? I don't use FEL, so I have no any subframe on a machine. Do I have to order from parts dpt if it's standard or do I need to design it myself?
The purpose of a front blade will be not only the snow cleaning, but also the ground works - road repairs, landscaping, stump removing, rock pushing e.c.
Thank You in advance for Your help :)
   / Subframe for the Kubota M9000 front blade? #2
I don't know about your model but I had a front blade on a L3130 Kubota useing a sub-frame....Had to remove FEL(I know you don't have one) sub frame for this tractor was a factory quick mount...check with your dealer?
Pinned to the back hitch and a couple of brackets on the side of the tractor.I think I had about $2500 U.S into this.Didn't work real well for dirt work:great for snow.You might want to look at a heavy duty rear blade for dirt work...a lot less money.
   / Subframe for the Kubota M9000 front blade? #3
On your front blade idea it swing right and left if you want to control the quality of the grade. A rear blade does a very nice finishing grade when it can swing R/L . Rear blades are terribile for pushing material backwards. Front blades dig in when finish grading.
Craig Clayton
Yeah, I had a talk with a dealer. They said there's nothing in the catalogue about sub-frame. They can supply standard tractor parts only.
You're right, front blade needs additional investment.
I have a look at the rear blade (pic attached). It might also be attached at the front, but in this case you need front 3ph.
So I'm at a nonplus ...
Craig Clayton
Actually I worked with both blades on a L tractor - front with cylinder (without a sub-frame, what was quite risky) and still have rear blade. Yes, front blade has a swinging feature.
Both have advantages and disadvantages. Rear blade's main advantage - no need any sub-frame. But it's hard to do precise works with it, like You say, pushing backwards.
I'd prefer to realize an idea to have a blade to be able to attach it either to the front or to the back.
We'll see ..
Anyway thanks a lot, fellows, for Your advices.
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
WOODS 9021 BATWING MOWER (A57192)
WOODS 9021 BATWING...
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
2024 Land Pride FDR1660 (A53317)
2024 Land Pride...
Loadrite L2180 (A53317)
Loadrite L2180...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
