Sub soiler: want to build
   / Sub soiler: want to build #1
psient
Hi:
I've a Kubota L4400. I need a sub soiler. I was thinking of building my own . . . fashioned after the Fred Cain version. I will use a sheer bolt on the design.
Anyone built their own? Do you have the dimensions/materials. What would you suggest? I need this for my vegetable garden. I have an extreme problem with clay hard pan and subsequent lack of drainage.
Any ideas?
Thanks,
Jon
   / Sub soiler: want to build #2
something I made
   / Sub soiler: want to build #4
Here is a picture of the sub-soiler I built. I used `1" x 4" steel for the main shaft. No shear bolt, but I don't have big stones. Not pretty, but works great.
something I made
Your tine arrangement :) looks extremely effective but I need something deeper. My rototiller will get to about 8 inches. Beneath that it's hardpan. I'd like to get another 10 inches if not a little more.
Jon
Hi:
What are the thicknesses of the material you used?
Jon
   / Sub soiler: want to build #7
Jon
I don't know if you have enough hp at the drawbar with your tractor to pull more than a single shank ripper that deep. A parabolic ripper like this one may get your job done
http://www.worksaver.com/Manuals/r130-ws.pdf
   / Sub soiler: want to build #8
Jon
you could start with the arrangement I have and have a couple shanks with extensions welded to them, they are standard scarifier shanks like you'd find in a box blade
as is I can get about 12" or so deep
Hi:
I did that on my drag bucket ripper tool bar. Hit a buried fence post footing and broke the weld :(. That was enough to convince me of a shear bolt configuration.
Thanks,
Jon
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Rhino DB150 (A57148)
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2019 FORD F-350 SUPER DUTY SERVICE TRUCK (A58214)
2019 FORD F-350...
