Sub soiler: want to build
   / Sub soiler: want to build #1
psient
Hi:
I've a Kubota L4400. I need a sub soiler. I was thinking of building my own . . . fashioned after the Fred Cain version. I will use a sheer bolt on the design.
Anyone built their own? Do you have the dimensions/materials. What would you suggest? I need this for my vegetable garden. I have an extreme problem with clay hard pan and subsequent lack of drainage.
Any ideas?
Thanks,
Jon
   / Sub soiler: want to build #2
something I made
   / Sub soiler: want to build #4
Here is a picture of the sub-soiler I built. I used `1" x 4" steel for the main shaft. No shear bolt, but I don't have big stones. Not pretty, but works great.
something I made
Your tine arrangement :) looks extremely effective but I need something deeper. My rototiller will get to about 8 inches. Beneath that it's hardpan. I'd like to get another 10 inches if not a little more.
Jon
Hi:
What are the thicknesses of the material you used?
Jon
   / Sub soiler: want to build #7
Jon
I don't know if you have enough hp at the drawbar with your tractor to pull more than a single shank ripper that deep. A parabolic ripper like this one may get your job done
http://www.worksaver.com/Manuals/r130-ws.pdf
   / Sub soiler: want to build #8
Jon
you could start with the arrangement I have and have a couple shanks with extensions welded to them, they are standard scarifier shanks like you'd find in a box blade
as is I can get about 12" or so deep
Hi:
I did that on my drag bucket ripper tool bar. Hit a buried fence post footing and broke the weld :(. That was enough to convince me of a shear bolt configuration.
Thanks,
Jon
HAMM HTC15 TRENCH COMPACTOR (A52709)
HAMM HTC15 TRENCH...
2014 REITNOUER MAXIMISER 48' FLATBED TRAILER (A58018)
2014 REITNOUER...
KOMATSU PC138US-10 EXCAVATOR (A52709)
KOMATSU PC138US-10...
MASSEY FERGUSON 275 TRACTOR (A58375)
MASSEY FERGUSON...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
2020 4-Fuel 800 Gallon Fuel Tank, Model 4F-838, S/N 4F-838811/20, Nominal Capacity, 838 Gallon/3172 (A59076)
2020 4-Fuel 800...
