Sub-Soiler how deep and how far apart?
   / Sub-Soiler how deep and how far apart? #1
DonWorrell
Pleasant View, TN
Mahindra 3325
I own a 35 hp tractor and just bought a TSC sub-soiler. How deep should I run it and how far apart should I make the cuts?
Don
   / Sub-Soiler how deep and how far apart? #2
Pull as deep as you can, to get to the Subsoil. How far apart you go depends a lot on personal preference and what you are subsoiling for? I usually go about 3 ft apart and if I have a low spot holding water and want to make it drain, I will checkerboard that area. Ken Sweet
   / Sub-Soiler how deep and how far apart? #3
Don
I hope your TSC sub-soiler lasts longer than mine did. Mine had a usable life of about 5 minutes on my 32hp kubota. One of the welds broke then it started to twist and bend.
   / Sub-Soiler how deep and how far apart? #4
All good Subsoilers will have a shearpin in them to prevent such disasters. Ken Sweet
   / Sub-Soiler how deep and how far apart? #5
I would take that one back for a full refund.
   / Sub-Soiler how deep and how far apart? #6
I own same subsoiler....and have a lot of rocks. I was wondering if I could use a lighter bolt in place of the top pin(of the 3 point hitch) to use as a shear pin. Opinions?????? thanks . I have a 28 hp massey.
   / Sub-Soiler how deep and how far apart? #7
Be a good idea to check and see what the machine would hit if it sheared the bolt. Sure wouldn't want to hit the tractor. Ken Sweet
   / Sub-Soiler how deep and how far apart? #8
I looked at the book for my JD 22A, it states that the sub soiler will shatter the ground 2' from the blade. Their for 4' passes should be made. It does have a shear bolt to prevent damage.
   / Sub-Soiler how deep and how far apart? #9
I do not understand any part of this last reply .....it does not have a shear pin and .......what does shatters the ground 2' from the blade mean???
   / Sub-Soiler how deep and how far apart? #10
He is talking about the book that came with his JD 22A sub soiler. His sub soiler does have a shear pin. Your's don't, and his book said that making 4' passes with the sub soiler is how far to space the cuts that the soil will be shattered 2' from the blade as it cuts the soil. In other words when you dig the soil it will crack the soil 2' from where you make the cut under ground.
Willmar 4300 Wrangler Loader (A51039)
Willmar 4300...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A51219)
2015 VOLVO VNL...
Headache Rack (A50860)
Deere 9970 Cotton Picker (A51039)
Deere 9970 Cotton...
Tarter 2 Horse troughs (A50860)
Tarter 2 Horse...
Toro Self Propelled Lawnmower (A50860)
Toro Self...
