stuck in 4wd
   / stuck in 4wd #1
gino45
Hawaii
kubota b7100
My B2710 with 260 hours runs great. Never had any issues other than those created by me; however, I am now unable to put it into 2wd. When I push the lever forward to 2wd, it will pop back up into 4x4 as soon as I start moving. Any suggestions as to a fix for this?
   / stuck in 4wd #2
gino45: If your last direction in 4WD was forward; reverse the direction of the tractor a few feet first, then select 2WD. That works for me. I think your tractor has too few of total hours to be an adjustment problem.
   / stuck in 4wd #3
My goes out of 4wd much easier if I pick the front tires off the ground with the loader.
   / stuck in 4wd #5
Yessir, most of my troubles come from a loose nut at the steerin wheel...
RDnT
   / stuck in 4wd
Hey, that's pretty funny, RD!
After playing with the shifter and using reverse I did get it in what I believe is 2 wheel drive. And I learned a thing or 2 about removing the loader by trying that for the first time ever. A bit of a comedy of errors! Next time I will locate in a solid level spot for loader removal--and have some spare cotter pins.
So, thanks for the tips!
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
ExMark Quest Zero Turn Mower (A50860)
ExMark Quest Zero...
2017 JOHN DEERE  30G (A50854)
2017 JOHN DEERE...
2025 K0608 UNUSED 3-Rail Style Fence Panels (A50860)
2025 K0608 UNUSED...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A51039)
Mitsubishi FG35...
