Steering problem with my Farm Pro 2425
   / Steering problem with my Farm Pro 2425 #1
Long lane farm
All- Any idea why when I had my steering cylinder rebuilt on my farm pro that I no longer have steering? Could there be an air bubble in the line that does not allow me to steer? I took the steering diverted off the tractor took it apart and it does not appear to be plugged up.
Thanks for any help that someone can give.
   / Steering problem with my Farm Pro 2425 #2
It is the 200 series and yes, I did make sure that the fluid was topped off. I was not sure if the steering diverter (at the bottom of the steering column) could go bad. I thought that it might be plugged up fro the seals that were ripped/torn in the steering cylinder.
Dean
   / Steering problem with my Farm Pro 2425 #5
Yep, what Tommy said. Pull a cylinder line and put it in a bucket and see if you get any flow while turning the steering wheel...
   / Steering problem with my Farm Pro 2425 #6
It's fairly common for the nut which holds the steering piston to come loose at which point the piston moves but doesn't do anything.
Thanks all for the information. I will try these ideas and with any luck, I will have use of my tractor again.
I have tries to bleed the lines but and they have plenty of fluid going to them. I have no pressure going to the steering cylinder, and I am not sure if the priority valve has an issue or the steering valve (the one that the steering wheel attaches to) may be plugged. Any idea what pressures the lines going to the steering cylinder need to be at?
   / Steering problem with my Farm Pro 2425 #9
The steering system consists of three major components -- the cylinder, which moves the front wheels back and forth. It's double-acting, it has two hoses going to it, if one hose has more pressure than the other it will move toward the one with lower pressure. The steering valve, which is really a pump -- spin the wheel one way and it pumps one way, and spin the other and it pumps the other. The diverter valve, which detects if one of the hoses has a higher pressure (from the steering wheel being spun) and supplies fluid at pressure to that side and takes it away from the other, providing the power assist.
Here's what I see as the diagnostic point: the steering should work without the power assist. If you spin the steering wheel with the engine off and the front wheels don't move then something is amiss. It could be the cylinder bypassing, it could be the steering valve isn't moving fluid, or it could be the diverter valve is leaking into the rest of the hydraulic system.
If you're getting zero steering at all this isn't a subtle problem, so you can do some testing with the engine off. If you disconnect one hose from the steering cylinder and spin the steering wheel you can see if the steering valve is working at all. If you spin toward the disconnected hose you should get a stream of fluid out of it. If you spin away from the disconnected hose you shouldn't get any fluid out of the cylinder unless it moves. If the cylinder produces fluid without moving then it's bypassing. If spinning the wheel doesn't produce any fluid then the steering valve isn't working.
I wouldn't suspect air, it should be self-bleeding and all of the components are below the tank. But everything I know is self-taught...
   / Steering problem with my Farm Pro 2425 #10
I have a pressure gauge on my main line where it enters the loader valve. It shows overall system pressure and I have seen pressures around 500 PSI when loading the steering system...
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
GARDNER DENVER 480 VOLT AIR COMPRESSOR (A50854)
GARDNER DENVER 480...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
CATERPILLAR 12" BACKHOE BUCKET (A51242)
CATERPILLAR 12"...
