Steel tires
   / Steel tires #21
I have not personally seen it on a tractor, but I recall reading that the old Lanz Bulldog tractors used a powder actuated starter. These were single cylinder, two cycle, air cooled diesel engines with a rather large displacement. If you did not use the powder starter it took two strong men to turn it over using a long bar on the flywheel due to the high compresson ratio. I think I would opt for the powder starter./w3tcompact/icons/wink.gif
   / Steel tires #22
Thanks MJB and Roy Jackson.
   / Steel tires #23
New to this board.
These are on my 8n, bought the wheels off of ebay.
The below link shows the side view, the wheels seperated and the front view.
http://www.ytmag.com//nboard/messages/325834.html
The wheels ride rough on asphalt and cement but comfortable on dirt, it rips up the ground when getting traction. I can bury the wheels if the boxblade gets stuck on a stump, clearing out my 5 acres. Got these after my good tires got torn up on roots and stumps
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A55314)
2023 Kubota...
2017 Ford F-550 Enclosed Service Truck (A53422)
2017 Ford F-550...
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
