STEAM ENGINE QUESTIONS.
   / STEAM ENGINE QUESTIONS. #1
crash325
Elite Member
Tucson AZ
New Holland TC-45
Steam engines will run in either direction. How are they started to go forward or reverse.
How is water added to the boiler. More presser is needed to get the water in.
Maybe someone on TBN will know.
There were steam tractors, must have needed to back up some times.
   / STEAM ENGINE QUESTIONS. #2
I have seen small engines where someone started the flywheel in the direction they wanted it to turn.
On old trains they used reversing the steam flow in the pistons to make it go backwards.
   / STEAM ENGINE QUESTIONS. #4
I don't think they reversed the flow of steam. They operated a reversing gear. The steam still travels the same direction, but the reversing gear moves an eccentric to make the wheels go in the opposite direction....
Reversing gear - Wikipedia
   / STEAM ENGINE QUESTIONS. #5
I always wondered about that too.
I guess for the water, they just use a small displacement pump.
   / STEAM ENGINE QUESTIONS. #6
   / STEAM ENGINE QUESTIONS. #7
Here's a really old movie with no sound, that explains it really well! It shows the reversing gear. The steam always travels in the same direction. They don't reverse the flow of the steam to make it go in reverse....
   / STEAM ENGINE QUESTIONS. #8
   / STEAM ENGINE QUESTIONS. #9
It gives the appearance that the steam is flowing in the opposite direction, but it isn't. It's still going back and forth as before. It's where the linkage pushes on the eccentric that determines the initial start of which direction the wheels are gonna turn, not the direction of steam flow. The steam just goes back and forth back and forth regardless of which direction the train is moving.
   / STEAM ENGINE QUESTIONS. #10
As for how they add water.... they use the pressure of the boiler to push water into the boiler. Sounds impossible, doesn't it? How can one force overcome itself?
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
John Deere 4240 (A53317)
John Deere 4240...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A55852)
2013 Freightliner...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2012 Ford Econoline Cargo Van (A56858)
2012 Ford...
