Starting with PTO Engaged
   / Starting with PTO Engaged #1
bobframe
Bronze Member
North Georgia
Kubota L3010 HST, Kubota RTV
Forgive me if this has been covered elsewhere.
My Kubota L3010 HST is doing something that seems different to me. Yesterday I tried to restart the tractor (thought I had the clutch pushed in) and it was dead. I noticed that the PTO lever was engaged, so I disengaged it and the tractor started normally.
My question is this: Should the tractor start if the PTO lever is engaged and the clutch is pushed in?
   / Starting with PTO Engaged #2
What you experienced is how it is supposed to work. If you had an implement attached you could have done some real damage.
Joe
   / Starting with PTO Engaged #3
Even my 1983 Cub Cadet 982 won't start with either of the pto's engaged.
Joe
Thanks for your quick reply.
My tractor will only start if clutch is engaged. If clutch is pushed in and PTO was engaged, wouldn't the PTO be immobilized upon starting? How would "real damage" be done? For example, lets say I was bush hogging and turned tractor off without disengaging the PTO. Upon restart the clutch would be pushed in and only after releasing the clutch would the PTO again turn. Seems like a safe start to me. What am I missing?
   / Starting with PTO Engaged #5
Any tractor with independent pto the pto would be turning when the engine was, requardless of the clutch position.
   / Starting with PTO Engaged #6
My B7500 HST works the same as your L3010. If will not start unless the PTO lever is in neutral and the clutch is depressed.
OK, so I can stop worrying that somethings wrong. Given a choice between my understanding being deficient and the tractor being broken, its a whole lot simpler to fix my understanding. Thanks guys.
   / Starting with PTO Engaged #8
I think the manufactures and safety people want the tractor to be started in a neutral state, then, the operator can choose what implements and gears are started. You may be the only operator at your household but many pieces of equipment are operated by more than one person. How are they to know you left the bush hog engaged? They start the tractor thinking it is in neutral and let the clutch out not thinking it was engaged. Was the family pet under the mower? What if it was a tiller back there...do you want it to run as soon as the tractor starts?
Brilliant answer. Now I understand this. It really could be a disaster. Thanks.
   / Starting with PTO Engaged #10
Perfect statements and very realistic examples!
Remember: Accidents happen fast!
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
2013 Ford F-150 (A50397)
2013 Ford F-150...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
2016 Ford F450 (A49461)
2016 Ford F450...
