START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800??
   / START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800?? #1
jodebg
Platinum Member
New Hartford, CT
Kubota B-2650
Just purchased this 2004 b-7800 with 422 hours. Thinking of using Rotella T6
Full Synthetic motor oil. Will switching to the full synthetic cause any problems?
Any other oil that you would advise using on this 30hp 4cyl.?
   / START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800?? #2
T6 5W40 is an excellent choice. Also, Valvoline Premium blue full synthetic 5w40 is another excellent choice.
   / START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800?? #3
No. Use 5-40 DIESEL oil with CI NOT SI rating. And you don't need all caps in the title line, it's considered shouting and totally unnecessary.
Manual calls for 10-30 or 10-40 oil. Is it ok to use 5-40?
What is diesel oil with CI? Regular diesel motor oil-not full synthetic, or synthetic blend oils?
Any brand that you advise?
   / START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800?? #5
I switched my tractor to mobil 1 TTD when it had 1950 hrs. Runs great and starts much easier in cold weather.
What is Mobil 1 TTD? Is this a 5-40 full synthetic for diesel engines? Ran a search and did not find any info..
   / START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800?? #8
gas oils are API 'S' rated
diesel oils are API 'C' rated.
Many times you see oils that carry BOTH 'S' and 'C' ratings.
the letter after the S or C is the current revision level.
CI, CJ etc. sometimes you get a number after that.... denoting further info.. like CI-4 etc..
Make sure you use a C rated oil of at least the specs in your manual.
And yeah.. many use a synthetic C rated oil in 5w40. I use the valvoline 5w40 premium blue ful syn in my diesel trucks.
   / START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800?? #9
Diesel synthetic for Diesel engines specifically. CI= Compression ignition; diesels. SI= spark ignition, engines with spark plugs/gasoline.
Rotella, Mobil 1, Amsoil, Valvoline, etc.
BTW, the 5w-40 gives you a wider low temp range in the N. England climate than a 10-40 oil. I want the lowest temp starting advantage possible; you should also for CT climate.
   / START USING FULL SYNTHETIC ENGINE OIL AFTER 400 HOURS..2004 B7800?? #10
Not only will it NOT cause any problems, it will solve some issues before they become problems.
Plus, it will start like summer in cold temps, lubricate the bearings much faster and extend engine oil intervals. I believe synthetic pays for itself.
Grooming Mower Attachment (A50860)
Grooming Mower...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
2007 Jeep Compass Sport SUV (A48082)
2007 Jeep Compass...
UNUSED Galvanized Wire Rope with G70 Hooks (A50860)
UNUSED Galvanized...
Mini ATV (A50860)
Mini ATV (A50860)
