Sprayer decision...please give me your opinion
   / Sprayer decision...please give me your opinion #1
HCJtractor
Veteran Member
upstate South Carolina, Greenville
Kubota M6800, Massey Ferguson 240
I want to build a sprayer to apply herbicide to plots and trails. Total acreage would be about 15 with the average plot size of 2 acres. I have a Fimco ATV version with a boom that works ok but the 25 gallons runs out fast, so I need a bigger one. I am thinking 100 to 200 gallon size.
I will use it on two properties, neither has a good water source. One has a cistern (that will require filtration) and the other will have to be begged from a neighbor, neither of which really suits me. Another factor is I would have to transport the tractor if I use a 3 point hitch model.
Therefore I am leaning towards a trailer style so I can take water to the property from home, and either pull the sprayer in the field with a tractor if it is there, or with my truck rather that having to transport the tractor. Complicated!
So a nice trailer with a 200 gallon tank would be ideal, but what pump?
My question is are there any 12 V pumps that would handle this demand and have acceptable flow? Obviously a PTO pump is better, but I could not pull it with a truck. Or what about a gas driven pump that would allow either the tractor or truck to be used? I really don't want to spend 2 or 3 grand on one, as I would rather be cheap and build it myself, but I have to come up with a design.
Ideally I would like a system that would allow me to drive to my property, drive around to all the plots and dispense the herbicide, and be done quickly. I think a trailer style would be better in this regard, and would allow me to drive it home to clean it with a good water source.
Anyone use a skid type sprayer on a truck with success?? If so, with what pump? Thanks for any advice and thoughts.
   / Sprayer decision...please give me your opinion #2
Remember the weight. A 3 pt with 100 gal is 900 lbs. If you have a smaller tractor that is an issue also soft ground can be a problem. For a tank look at a plastic shipping tote for liquid. Approx 200 gallon clean plastic tank for around $75 on craigs list all the time here. They have a light metal frame around them and you can move the around by hand when they are empty. For the pump sounds like you will have good luck with a gas engine pump. I don't think an electric pump will have enough volume to make you happy for the area you want to cover. With the light tank and gas pump you could move it from a trailer to the truck easily.
   / Sprayer decision...please give me your opinion #3
Delavan makes a few 12V pumps that will pump 5 GPM at 45 psi. I use a Delavan Fat Boy that pumps 7 GPM. Just remember the motors on these pumps are not thermally protected. They will burn up if the motor gets above 140 degrees F.
I use a 300 gallon poly tank and this pump will empty it in 1 hour. You can cover a lot of ground in 1 hour. Just remember to check the motor temperature (if you can keep your hand on it then the temperature is below 140) and shut down and let it cool down if it gets too hot.
Thanks. I will check those out. How do you have your tank rigged? Is it a trailer? Where do you get a power source? Alligator clips to your battery, or a dedicated battery, or a plug? A good 12 volt pump would sure make my design easier and allow me to use either my truck or my tractor to dispense.
   / Sprayer decision...please give me your opinion #5
I've seen 275 and 330 gallon IBC totes (and have 4).
attachment.php
But have not seen 200 gallon size. Mine are about 70lb empty. Add 8lb/gallon for fluid.
   / Sprayer decision...please give me your opinion #6
You might be best served to custom build one to fit in the bed of your truck. Things tend to get bounced around a lot on trailers, and having it in the back of your truck would really simplify things as far as traveling. Though, I think it would be nearly impossible to maintain the proper speed for spraying in a truck.
Another option would be to just get a large water tank for the bed of your truck and just take the water with you, but you’d better have a truck that can handle it.
attachment.php
How do these totes I see commonly compare to a plastic tank that you can buy (say like the ones at Tractor Supply). Are they as durable and what bulkhead fittings do they have? What should I look for if I buy a tote or are they all about the same?
If I build a sprayer, it seems the tank needs two outlets; one for the pump to pull through and one for the re-circulating pathway. A lot of the tanks I see only have one outlet. I wonder how guys recirculate. Do they drill a new hole in the tank and use a screw on fitting?
I never though about ground speed in a truck being a limiting factor. I guess it also depends on what pump you have and what its flow is. Obviously, a
12 V pump would be less than a PTO or gas driven one. And I never considered the bouncing to be a problem with a trailered sprayer.
My main goal is to get a system I can "get her done" quickly. I wish I could build a rig that holds enough for 8 or 10 acres, is portable enough to drive to the site, and will allow me just to drive around and sprays the plots, and then go home. And not spend all day or require transporting a tractor if it is not on site where I need it. If my truck had a PTO it would be easy! That's why I want to get all the ideas and advice I can in brainstorming a design.
I have no problem building a custom rig, and as a matter of fact, I would prefer to as I think I can save lots of money doing it myself. And my truck is a F 350 so weight is not a problem. And my tractor is plenty big to handle 200 gallons on the back if I decide to go to a 3 point hitch model. The commercial ones I see that look appealing all are in the $3000 range, and I just can't go that much.
   / Sprayer decision...please give me your opinion #8
The large caged containers are plenty strong. They have one large open/shut drain valve at the bottom, so you’ll have to drill holes. But, you’ll have to drill holes for inlet/outlet in most any tank you get, except for those made specifically for sprayers.
A constant vehicle speed is critical for spraying a lot of herbicides, and it’s very hard to maintain steady, slow speeds in a truck sometimes. At least for me it is.
   / Sprayer decision...please give me your opinion #9
For the OP's use I'd recommend several totes.
Get the ones you can use for drinking water (might as well be safe) and you should be able to find them for about $60 to $120 each (I think a 200 gallon poly tank at Northern Tool runs about $300).
The IBC's I've got have a large opening (2"?) on the top w/ a cover and a valved opening on the base.
I've a rather complicated rain water collection system set up.
attachment.php
The broken cooler (lidless) collects water from about 500 sq ft of roof and it drains into the IBC. Collected about 150 liters the first rainfall :)
If you can drive the truck around to spray you can fit a sprayer pump head to the tote.
What I would do is put 2 totes in the truck on pallets, fill them, tie them down well. Trailer the tractor with either a 3pt pallet mover like I have and another full IBC w/ sprayer or I'd use the 25 gallon the OP has. Drive to site 1, unload the tractor (w/ pallet mover and IBC or 25 gallon & sprayer attached). Spray. Refill from truck when needed. Then as soon as I had one of the IBC's (clean and pure) in the truck empty I'd carry it off the truck, drop it at one of my sites, drain the full one into the empty one and thus leave about 300 gallons of clean water at the site.
I've 5 separate parcels in Mississippi away from plumbing. I'd like to eventually drop one or more IBC's at each site as a water "source".
   / Sprayer decision...please give me your opinion #10
Water left in those tanks won't stay safe for long, without treatment. You may already realize this, but I thought I'd mention it.
NEW FLAND FL45 RUBBER TIRED LOADER powered by gas engine, 13.5hp, equipped with OROPS, 39in. GP (A40023)
NEW FLAND FL45...
Massey Ferguson 1140 4WD Tractor Running Machine (A43155)
Massey Ferguson...
Combo Toilet and Water Trailer (A41853)
Combo Toilet and...
TPM Rubber Track (A43158)
TPM Rubber Track...
NEW (2) 8FT. PALLET FORK EXTENSIONS FORKLIFT ATTACHMENT (A40018)
NEW (2) 8FT...
2018 Freightliner Cascadia T/A Daycab Truck Tractor (A43690)
2018 Freightliner...
