spray Pam on your snowblower to prevent clogging
   / spray Pam on your snowblower to prevent clogging #41
I use EZ-Slide, a graphite paint, on my blower chute. ~~ grnspot110
   / spray Pam on your snowblower to prevent clogging #42
Never tried it myself but what about KY - That stuff seems pretty slick.:laughing: Of course your wife might wonder what you are doing haulling it all out to the shed.
   / spray Pam on your snowblower to prevent clogging #43
Go with the "Pam" it may not be the best but you will get some comedy relief
( interesting language)
when the wife needs it and finds that you used it all.
Dan
   / spray Pam on your snowblower to prevent clogging #44
I smear a stick of butter on the inside of my chute / impeller housing before each storm. :thumbsup:
You sir, apparently aren't worried about your snow machine's cholesterol! :D
   / spray Pam on your snowblower to prevent clogging #45
After finding out from my brother (tree surgeon) that he and all his colleagues use vegetable oil for their chain-lube in their saws, I use it too, but realised that it might work to keep the snow off things.
I now have an old paint spray-gun with it's pot full of sunflower oil... whenever the back-blade and bucket end up dry, I give them a good coat of oil. .... and nothing sticks. Same for the tractor itself: A light dusting on the wheels, axles underbelly makes sure that no snow sticks :)
   / spray Pam on your snowblower to prevent clogging #46
I use nothing. I keep the snowblower at the same temperature as outside. I do not have problems with it sticking except after snow blowing I have to keep auger cable engaged, because the snow will melt down and freeze linkage up, when I start it again it will thaw out shortly after.
   / spray Pam on your snowblower to prevent clogging #47
I used to spray Pam on my cross country skis, and it worked real well. I haven't skied in a few years, and since discovered Fluid Film. If I ever get the skis out again, I would use FF instead of Pam.
   / spray Pam on your snowblower to prevent clogging #48
Based upon comments I read on TBN, I picked up some FF at a local NAPA store and used it on my snowblower and a metal shovel. Today we got a nice sticky, wet snow - and while I have never had a problem with chute clogging, when I was done there was very little snow packed into the usual corners, and what there was broke free with ease. It also did a great job keeping the snow from sticking to the shovel, which has always been a PITA.
Fluid Film may be one of the best tips I have picked up in a while, and is one I will share with others.
JB
   / spray Pam on your snowblower to prevent clogging #49
I've been using black Graphite for a long time ,works well for me,
I also spray the loader bucket and the backhoe bucket once in a while !
   / spray Pam on your snowblower to prevent clogging #50
Use what ever lubricant available on hand. Maybe not green nor eco friendly.
But to my credit - I do buy a spray can of cheap vegtable oil based no - stick pan lubricant every winter - and living in A Great Lakes Snow Belt Area - must say - I make it through each winter okay with great success.
How many ways can it be said - this is a no-brainer?
2017 INTERNATIONAL PROSTAR+ (A58214)
2017 INTERNATIONAL...
Mini Skid-Steer Hydraulic Skeleton Grapple Bucket (New/Unused) (A59225)
Mini Skid-Steer...
2819 (A58376)
2819 (A58376)
2022 Big Tex 14LP Dump Trailer (A57148)
2022 Big Tex 14LP...
1408 (A57192)
1408 (A57192)
Jack Daniels Metal Truck (A57454)
Jack Daniels Metal...
