Splitting a Buck
   / Splitting a Buck #1
CrashandBurn
USA
2010 TYM 233
Any tips?.......I've built a pair of splitting stands and am ready to go.
   / Splitting a Buck #2
Splitting stands? Man what a luxury. I have split countless tractors over the years and always just used a couple of floor jacks. The only time I bothered with stands was when I was splitting into 3 parts, the engine, the clutch housing, and rear differential, the stands were to hold up the clutch housing section on both ends.
The only advice I can give is that when going back together don't force it. If it doesn't go, something isn't lined up. You can use bolts as a guide but don't use them to pull the halves back together. If you find yourself forcing it take a break, come back and give it another try, if it still doesn't go separate the parts and recheck things then try again.
Brian
   / Splitting a Buck
thanks Brian.....
I'm mostly concerned with the hydra. lines and any gaskets, o-rings, ect. I might need.
1981 Case 245 2wd tractor with bushing (A51039)
1981 Case 245 2wd...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
Lot of 3 Dell Desktop Computer (A48083)
Lot of 3 Dell...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
2013 COACHMEN CATALINA TRAVEL TRAILER (A50854)
2013 COACHMEN...
Sink with table (A50860)
Sink with table...
