Source for 1-3/8 6 PTO direct mount chain sprocket
   / Source for 1-3/8 6 PTO direct mount chain sprocket #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I did a quick search of the net. didn't find anything useful.
Tooth count is not so important, just something "small" for #40 or #50 roller chain.
References?
   / Source for 1-3/8 6 PTO direct mount chain sprocket #2
Yep, I couldn't find anything either.
May have to do some machining and welding on a shaft adapter.
Thanks for looking
That's what I came up with also.
I made a purchase of a universal joint yoke, but it will be machined just the same. It's on it's way.
   / Source for 1-3/8 6 PTO direct mount chain sprocket #5
I'd think twice about running a sprocket directly off of the PTO shaft.
I'm assuming you intend to use the bearings that support the PTO stub shaft on the tractor to react the loads that the sprocket will see?
I 'm not sure those bearings weret designed to take much "overhung" reaction load like a sprocket, way out there at the end of the shaft, can deliver.
A lot of my concern depends on if your project will be pulling a lot of torque through that shaft.
If so, then consider mounting the sprocket to an independently supported shaft, as a tiller or brush hog do.
   / Source for 1-3/8 6 PTO direct mount chain sprocket #6
I have never seen a 6-spline sprocket configuration. And I have dealt with about every kind of sprocket imaginable. My concerns are the same as Baby Grands.
If you plan on direct driving off the PTO shaft, you are gonna want a frame and mounted bearing aft the sprocket to support the PTO shaft.
Better yet would be framework for whatever you are building, and drive the sprocket with a short PTO shaft.
So....just what is it you are working on?
   / Source for 1-3/8 6 PTO direct mount chain sprocket #7
   / Source for 1-3/8 6 PTO direct mount chain sprocket #8
Years back JD 2 cylinder tractors had a chain driven implement lift that was powered by the tractors pto. JD cotton stripper was powered by sprocket & chain. Rd hay balers have some fairly decent loads transmitted from chains
   / Source for 1-3/8 6 PTO direct mount chain sprocket #9
Sweepster brooms , now Paladin Attachments, used them years ago on their smaller machines. A chain sprocket with
a separate 1-3/8" x 6-spline adapter.
The part numbers were: 06-0094 sprocket, 50H15, and 06-0087 splined hub.
They're probably still available.
-David
a135376.jpgThe units must show up from time to time
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2013 Ford Escape SE SUV (A50860)
2013 Ford Escape...
Lift station Pumps (A49461)
Lift station Pumps...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2014 Kinze 1100T Dual Auger Grain Cart (A50657)
2014 Kinze 1100T...
PALLET OF BRAKE AND AXLE PARTS (A50854)
PALLET OF BRAKE...
