Soooo This is how its done
   / Soooo This is how its done #11
Somebody should have purchased lottery tickets on that day. Notice that white cross in the background? A previous "cowboy" that tried the same stunt.
   / Soooo This is how its done #12
Did anybody scroll down and read the comments. Everybody is praising the tractor operator for pushing the tree down with the loader and snowflaking on anybody that mentions using a chainsaw, or what he did was unsafe.
   / Soooo This is how its done #13
Yes, I saw the comments. Ignorance was rampant on that day and at that location. Darwin will eventually resolve this situation.
   / Soooo This is how its done #14
At least he (his family) had a video when the lawsuits start.
   / Soooo This is how its done #15
I don't see it as overtaxing his equipment. Granted, he's taking it closer to limits than "normal", but it's not like he's hitting a concrete curb with his bucket at 5mph. Yep, a stick could of went through oil pan, more likely root ball would lift tractor by front axle.
I see the biggest danger in that a widow-maker may come down and crack his skull when shaking the tree, or worse yet, it could dent in his hood. Granted, maybe less likely on a healthy looking conifer tree than a dead hardwood.
He's also lucky that when pushing it away that tree didn't bow then snap back right up the loader arms into his lap before he could stop, or worse yet, rip out a hydraulic line.
   / Soooo This is how its done #16
I can't believe the comments I'm reading here. Tractors are made to be used. Enough said!
   / Soooo This is how its done #17
Tractors are not completely idiot-proof (thankfully). Just because it can doesn't mean you should. There are mechanical stresses which can be induced that were not intended to be be accommodated by the equipment's design. Things will bend and twist if the operator simply fiddles with the controls with no mind toward some basic principles of physics. As merely one example, when he is carrying away the tree, the fact that the rear wheel opposed to the majority of the load is coming off the ground is pretty good indication of a substantial imbalance being placed on the loader frame and associated cylinders.
   / Soooo This is how its done #18
Trees are more creative than you are.
That is, they can think of ways to mess you up that you can't even imagine.
If you think you can imagine all the ways it can get you, you're wrong, it can invent a few more.
Get a cable and pull it over from a safe distance. ....of course the cable can snap and kill you, just like a chain saw could if you cut it down. Just like a stump grinder...etc....never mind....do what you want ...it's a free country.
p.s. Yes a rear wheel is off ground, but one can't tell if this is a great imbalance to be concerned about. A nearly balanced lift will typically only lift one tire off the ground because front end pivots.
   / Soooo This is how its done #19
I'm not sure what you're on about. I never mentioned anything about tree-felling and how to go about it safely. My post was simply putting forward the fact that you can break a tractor by operating it like a monkey.
   / Soooo This is how its done #20
Like most things its how its used.
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A52707)
2016 CATERPILLAR...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
202475 (A54757)
202475 (A54757)
