Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket
   / Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket #11
I built a narrow (6") ditch bucket for my 580B several years ago, have clay soil, spent as much time dumping as filling :=(
If I ever need that function again, I'll either rent a trencher or build one of these (don't remember where I got the pic, I do a LOT of "researching", spelled T-H-E-F-T :=)
   / Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket #12
You bucket looks like a cribbing bucket. We use them to crip out the ballast between crossties on the railroad. They do pretty good for digging narrow trenches too.
   / Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket #13
I found this somewhere.
  • selfcleaningbackhoebucket.pdf
   / Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket #14
Thanks fisherridge. Without the drawing was struggling with the design concept.
Hi,
That is the basically the thing I did except I welded the ends inside the bucket next to the upper edge. That way there is nothing to remove off the machine when you change buckets. I did not tie the two chains together with a cross chain, but made them quite loose, so they could flop around.
Joe
   / Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket #16
Hi,
Joe
So when you dump the bucket, the chains dont actually pull tight then??
I would think with them attached to the dipper like in the pic, that having them draw up tight when the bucket is dumped, would be more effective?
   / Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket #17
what no hand ties lol rail roader myself
   / Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket #18
Search google for "Mythbusters cement truck":D
2006 Chevrolet Impala Sedan (A54815)
2006 Chevrolet...
2021 BMW R 1250 RT Motorcycle (A55853)
2021 BMW R 1250 RT...
Mini Excavator (A55787)
Mini Excavator...
2021 John Deere R4038 Sprayer (A53485)
2021 John Deere...
UNUSED FUTURE FT36C STAND-ON SKID STEER (A57192)
UNUSED FUTURE...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
