soil and garden question
   / soil and garden question #1
anthonyk
houston texas
Century 3647
I've got 12 acres and I've been considering starting a garden for vegetables and maybe even some flowers. Most of my land is heavily wooded, but I've cleared an acre or so near the house.
My problem is that the soil is terrible. I mean really bad.
It seems to be solid clay, that gray sticky type, covered in a few inches of topsoil.
When I dug my pond I went down 15 feet and never got out of it, and I can tell you, that pond never leaks:)
Anyway, I'm assuming that not much will grow well in clay so I've been thinking of just trucking in a dumptruck or two of dirt/topsoil or whatever experts might recommend, and maybe trying the raised bed approach. Maybe boxes, or just rows.
Any ideas, comments or suggestions from those of you in the know would be appreciated!
anthony
   / soil and garden question #2
I really like my raised beds. But need to learn not to import so many weed seeds in the soil i filled them with. They are pleasant to work in and can be more intensely planted. I also put in some soaker hoses for watering, about 6-10" down. No need to dig up the soil just cover with 10-12 sheets of paper and put your frame on top (or the other way around) and fill up the frames with dirt and ready to go.
   / soil and garden question #3
Sounds like the ideal case for raised beds. I would bring in top soil and compost, mix the two together and fill the beds. Automatic irrigation makes life much easier... I'd install that while you are building the beds. Leave enough room between the beds to get a cart or wheelbarrow in between. If you are building a big raised garden leave some main "highway's" for the tractor. Makes life much easier when you need to spread compost, harvest crops etc. if you don't have to carry everything from the end of the rows.
   / soil and garden question #4
I put in a raised bed to try out it's 3' x 20', box is made out of 2x6, I filled it with screened topsoil and compost. If you have adverse soil conditions it is the way to go, and you really don't need any powered equipment to be able to garden. It's the first year for the bed, but it's growing great. I water by hand when it's dry. I'll be putting in many more of these beds, they make gardening easy and fun.
   / soil and garden question #6
There is another great book called Gardening when it counts by steve solomon
talks a lot about different soil types, where and how to increase your soil fertility, pros and cons of raised beds, etc.
all that being said. I do have raised beds, hd and lowes had lanscape timbers for 1.97 each, so i have 11 4x8 beds and 1 2x 24' bed, this has given me more then enough room to grow. i do much, and add fert and lime every year. the garden itself is about 3 years old and i figure it will take another 3 for the soil to be where i want it. good luck. and remember if you have deer or rabbits fence it rabbit guard on the bottom and other fence on top. if its not at least 6' high the deer will get in.
later
   / soil and garden question #7
Before you read any farther I must warn you that gardening can be ADDICTIVE. Just so you know.
Raised beds sound like the way to go as others have said. The other thing you can do is to get some top soil spread it out and be sure it is about 6-8" deep. Add another 4-5" of good old compost. Till them together cover with black & white pages from a newspaper and spread another inch of dirt on top. Let it sit for a month or so, that will help kill off a lot of weeds. If weeds do appear pull them up and then you are ready for your first planting.
If you are starting your garden you might as well start a compost pile as well. Regardless if you go with raised beds or not. It is very satisfying to do and all the ingredients are there for free. I put everything in there from dry leaves, vegetable scraps from the kitchen, flowers after they die in the first frost, dry grass from my neighbor's field, horse poop from a near by farm. Let the heap sit over the winter and when it thaws out sometime in mid-May I start turning the pile. I collect some of the FRESH grass clippings from the first mowing in the spring, mix it into the pile and that will really get it going. I try to turn it every 2 weeks or so. (ie: fun with tractor) By the time all the vegetables are done the compost is ready as well. I just spread 3-4" compost on the garden till it in and start the whole process again with fresh ingredients.
Using the above method I have a good little garden that I started in very poor gravel that had about 6-8" of top soil, (or dirty gravel instead).
   / soil and garden question #8
you shouldn't use treated lumber around your beds where you are growing food.
thanks for all the tips. I really appreciate it.
I was wondering what you guys used to make the boxes.
I assumed that treated lumber would be a no no, but figured just about anything else would just rot.
Any suggestions?
thanks again,
anthony
   / soil and garden question #10
I prefer to till in commercial compost and let it decay for 6 months to a year, add some sand, then check the ph and see where your at. Adding top soil speeds the process, but it adds weeds. Sometimes a lot of weeds.
It can take several seasons of this to get to where you have good soil.
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2009 Ford Fusion SE Sedan (A48082)
2009 Ford Fusion...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2014 Jeep Cherokee Latitude SUV (A48082)
2014 Jeep Cherokee...
Diesel Fuel Tank with Pump (A50860)
Diesel Fuel Tank...
