SNOWPLOW L3010
   / SNOWPLOW L3010 #11
botaman2- Could you please post some pictures of the rear section of your subframe mount and control valve mount, and give us some info on the lift cylinder and control valve that was used?????? Please????
   / SNOWPLOW L3010
Hope these pictures will help!
   / SNOWPLOW L3010
more
   / SNOWPLOW L3010
1st picture=loader x-brace with front view of plow sub-frame rear support bracket bolted on.
2nd picture=back view of same bracket.
3rd picture=afar view of same bracket.
   / SNOWPLOW L3010
quick disconnect mounting bracket for angle cylinders.
   / SNOWPLOW L3010
Hydraulic lift cyl. fixed end mtg. point welded to FEL front assy.
   / SNOWPLOW L3010
All hydraulic plow lines plug directly into the FEL control valve with Q/D's. The lift cylinder connects to the left side of control valve,the angle cylinders(only two lines ,one from each cylinder)connect to the right side of the control valve.
   / SNOWPLOW L3010
Close up of hyd. cyl. and lines.
   / SNOWPLOW L3010
Sub frame rails are made of 2" sq. stock with 1/4" wall. The lift cyl. 3"bore x 8" stroke (Chief brand from Northern).The angle cyl. are replacement Meyers(also from Northern).All hyd. lines were made up at local Napa. I had to use Kubota Q/D on lines where they attached to control valve. Other Q/D's were not compatible.
   / SNOWPLOW L3010 #20
Very, very nice!! This is how I envisioned setting mine up. Your ft. end loader subframe looks a little different than mine, mine is a 2000/2001 edition, maybe that is why. Do you have the float function on yours? I was lead to believe, ( by our 2 local Kubota dealers), that the control valve that comes std. with the L3010 ft. end loader would have to be swapped out for a different unit if I wanted to have angle, lift, down pressure and float for plowing snow. Thank- you /forums/images/graemlins/smile.gif
2013 JCB 3XX Backhoe (A55973)
2013 JCB 3XX...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A55852)
2005 Toyota Tundra...
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2012 Ford F-550 Crew Cab SWAT Transport Truck (A55852)
2012 Ford F-550...
