Snowblower on 25HP non-hydrostatic
   / Snowblower on 25HP non-hydrostatic #41
Hello Radios1,
I subscribe to "Farm Show" as well, the problem is we are looking at our keyboards and offering our advise and council with our years of combined experience for what he is describing.
Having the simplicity of a mid mount PTO with a single stage snow thrower like the Reist Series 1000 in a wider width(5 feet) as long as it does not have a leaking seal and the drive lines and carrier bearings are greased will last a very long time as long as it it maintained. A mid point PTO seal leak requires the transmission to be drained completely to allow the seal and seal housing to be removed and replaced.
He has to have the ability to spread grit at the same time he clears the road of snow and having a rear mounted pendulum spreader like the Vicon gives him the most flexibility to do this.
He has to obtain 90 day quote for the repair and installation of the mid mount PTO and the carrier bearing and drive shaft.
Both Pronovost and Riest can provide front mount hitches for snow blowers and he has to decide whether he wants a three point hitch mount from Pronovost to carry the snow blower or a simpler system for the Rieset series 1000 single stage unit.
The Riest series 1000 single stage snow thrower will have plenty of torque and power as the snow blower rotor is 13 inches in diameter and it is much much simpler than a 2 stage snow caster as it does not have a impeller fan.
The Riest series 1000 single stage snow thrower operates between 600-700 RPM with the chain driven rotor just like the older single stage snow throwers on lawn tractors.
The mid point PTO on his mule will most likely run at 2,200 RPM at high idle and the prpeller shaft will operate at that speed through the carrier bearing and then the universal joint(s) which are attached to the 1/1 right angle gearbox which then transmits the power delivered from the Mid PTO to a cross shaft that rotates a smaller roller chain sprocket that is connected to the larger single tooth sprocket attached to the snow blower rotor.
It all comes back to the servicing dealer and the quality of work that they do and how well they follw the instructions on a different implement installation like a front mounted single stage snow thrower driven by the mid point PTO.
IN SAYING THAT using an propeller shaft driven front mounted snow thrower like the Riest series 1000 in a 5 foot width
will be simpler as the spreader can be left on the three point hitch all winter as long as its left empty and covered with a tarpaulin or the vicon hopper cover until it is needed to spread grit if it is left out side with the mule.
   / Snowblower on 25HP non-hydrostatic #42
Hello Radios1,
any idea what happens when you hit a rock with that, and the auger has frozen to the driven shaft?.. new snow blower transmission needed?.. I never liked the idea of shear bolts..
   / Snowblower on 25HP non-hydrostatic #43
I am going to either trade my 790 in on a 2520 with snowblower or try sell it and buy the 2520. The 790 has been great and is set up for firewood with a 3PT log lift with hydraulic thumb but if I cannot sell the 790 for a fair price I will keep it and buy an inverted Meteor pull behind 68" snowblower. I just listed it on CL this am.
   / Snowblower on 25HP non-hydrostatic #44
a fair price could be $4700. 2 John Deere 79 Tractor - Annawan, IL | Machinery Pete
   / Snowblower on 25HP non-hydrostatic #45
well i am glad my tractor doesn't look or price out like that one.
   / Snowblower on 25HP non-hydrostatic #46
What happens:
The 60 roller chain on the left side of the snow thrower that rotates the snow blower rotor simply breaks and you have to replace it entirely. Removing the pin that holds the access door on the left side shut allows you to have full access to the drive and driven sprockets to remove the broken drive chain and install the new one.
Having a roller chain tensioner and a roller chain breaker for #60 size chain and a box of #60 chain and a box of #60 master links handy is all you need.
Simple with no other work needed.
The only change I would make is to have #60H chain and sprockets as they are stronger and you can use one long cotter key to save on time and fussing whenever you break a chain if the cotter pin holes are lined up in a straight line and you will have less work in bending one long cotter pin than two small ones to get the snow thrower back in service.
   / Snowblower on 25HP non-hydrostatic #47
The new rubber shoes for the front alone would be close to $700.00 so its not worth that much for sure.
The rear shoes must have been in even worse shape than the front shoes!
   / Snowblower on 25HP non-hydrostatic #48
What happens:
ok, I guess that wouldn't be bad, needing to do that a few times a day then.. not having to do that at all would be better though..
   / Snowblower on 25HP non-hydrostatic #49
Hello Radios1,
I would never spend good money on a hydraulic drive snow blower when the single stage unit would cost less than 7K plus tax with the extended chute and #60H chain, sprockets, hydraulic rotation using a hydraulic cylinder, hydraulic spout control and spot lights on the chute.
if a hydraulic system was chosen it would need 2 very long number 12(3/4") or 16(1") hydraulic hoses and they would be close to $600.00+, plus the 4 quick connect hydraulic fittings which would be over $100.00 a pair plus the loom clamps to secure the hoses and the fitting caps for the hoses to the tractor frame plus the hose protecting wrap.
A hydraulic power pack would also require a cooling fan system for the oil as a high volume gear pump and gear motor 30-35 gallons per minute will be needed for the application.
   / Snowblower on 25HP non-hydrostatic #50
Hello Radios1,
the guy on the farm show link I posted did it for under $1000 and used a 40 gallon tank to avoid needing cooling fans. using the hydraulic motor, he can lift the blower all the way up without having to worry about the driveshaft..
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2019 Bomag BMP 8500 Trench Compactor (A57453)
2019 Bomag BMP...
2020 CAT 308 (A53317)
2021 BOBCAT T870 SKID STEER (A52709)
2021 BOBCAT T870...
2014 Takeuchi TB290 Mini Excavator, S/N 1851007797, Diesel Engine, Tag 24" Bucket w/Thumb, 18" Wide (A59076)
2014 Takeuchi...
