Snow plow wheels vs skids
   / Snow plow wheels vs skids #21
I have a Behlen Country ( Behlen Country | Farm and Ranch Equipment ) adjustable scraper blade for my 1023E to which I'd like to attach a pair of skids to regulate depth of cut when I'm dressing up my long gravel road. Does anybody know of a source for and how they might attach to this scraper? I also use it for moving snow when my Mickey-Mouse front-mounted snow blower craps out.
   / Snow plow wheels vs skids #22
Here are my plow castors. The have, 8" foam filled tires:
Don't slit the steel pipe. It's totally unnecessary. Just weld some tabs on it, and bolt it on with the existing edge bolts.
   / Snow plow wheels vs skids #23
looks like shoes/skids in the most common so will see if I can scrounge some materials since the cheapest thing on a Kubota is the operator.
That was awesome. And I'm in total agreement. Zero useful input, but had to say thanks for that.
   / Snow plow wheels vs skids #24
its a blower not a blade but here is how pronovost did it
P-INV-74 - Pronovost
interestingly, there are no skids on this blower- only a cutting edge
works fine on gravel- if its frozen
with wheels i would think an important need would be for them narrow enough/ hard enough to cut through the snow to the surface and a low enough blade/ blower that residual snow cannot pack under the wheels and cause a gradual rising of the device
   / Snow plow wheels vs skids #25
there can be a problem with wheels, I have a craftsman lawn tractor with a front snow blade, I had to put chains on the front wheels because they wouldn't turn in snow /ice, they would build up snow in front of them, and prevent the tractor from moving, chains fixed that.. with small wheels like you'd use on a blade or blower, that's not possible, and once the snow is at or above the center-line of the wheels, it's impossible for them to turn anyway!..
   / Snow plow wheels vs skids #26
The trick there is to mount a snow plow in front of those wheels so they never run into deep snow...
23018 (A55758)
23018 (A55758)
2016 Isuzu NPR Landscape Dump Truck (A56858)
2016 Isuzu NPR...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2017 Toro Workman HD Utility Cart (A56857)
2017 Toro Workman...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
2025 GPS Trailers MDR2014K 24ft. 7 Ton T/A Dovetail Equipment Trailer (A56858)
2025 GPS Trailers...
