Tires Snow handling: Turf Tires (R3) vs. Ag Tires (R1/R4)
   / Snow handling: Turf Tires (R3) vs. Ag Tires (R1/R4) #11
I have had NO problems in snow with the turf tires on my BX.
No chains; in 4wd and with rear ballast the tractor performs as you would expect it should.
wrooster
wrooster
Thanks - did you have a front-mount snow blower?
   / Snow handling: Turf Tires (R3) vs. Ag Tires (R1/R4) #13
Not a Kubota but I plow my driveway with 2wd and good turf tires (no chains). By "good" I mean the tires aren't worn.
   / Snow handling: Turf Tires (R3) vs. Ag Tires (R1/R4) #14
I've been using my BX2350 for the past 10yrs to plow snow w/ turf tires and never have an issue unless the snow is really deep (10+ inches) and wet and then sometimes I just can't get enough traction (tractor too light). But it's never stopped me, it just takes a few running starts to get it going again.
I've also used a rear snowblower for the past couple yrs and just got a front snowblower last yr but didn't get to use it yet.
I would say since you already have them is to give the turf a chance and see how you like it. If you don't think they do well for you, can look at changing them but I think you'll be surprised on how well they do.
   / Snow handling: Turf Tires (R3) vs. Ag Tires (R1/R4) #15
There is probably a 95% chance you will be fine with just turf tires. I have used all 3 types on various tractors and this is my overall conclusion. Turfs- best of the 3 on hard packed snow. R1 ags work great on deep snow or breaking new paths but tend to slide easily on hard pack. R4 industrial- I liked these the least. Not enough traction in deep snow and still slide on hard pack. R4 was the only tire that I needed the assistance of having chains.
Unless you are working on very steep slope you should be ok without chains as long as you have 4wd. Plow trucks rarely if ever have chains.
   / Snow handling: Turf Tires (R3) vs. Ag Tires (R1/R4) #16
Have plowed snow with my F2100 Kubota for the last 27 years (2400 hours on it) with turf tires and chains ( second set of tires and 2nd set of chains) It does a great job and the driveway has a 20% grade. I only can plow down hill and about 6 inches of snow at a time. Have to plow with the storm or use the MX5100 bucket loader to open things up. Chains on just the front big wheels. With chains it makes it a real beast and goes where you point it.
   / Snow handling: Turf Tires (R3) vs. Ag Tires (R1/R4) #17
Plowed a lot of snow with a BX2200 and turfs with the FEL. Put chains on after a couple of years and it was beast. I now plow with a B2620 using the FEL and a back blade-still have turfs only, no problems.
Will
   / Snow handling: Turf Tires (R3) vs. Ag Tires (R1/R4) #18
I Agee turfs work great in snow especially if your driveway is paved. In really deep snow in the grass not so good.
   / Snow handling: Turf Tires (R3) vs. Ag Tires (R1/R4) #19
bdhsfz6 - thanks for the tip. I was trying to avoid chains since my driveway was recently paved.
Rubber chains are an option but don't last long and in my experience, don't work that well. I use twisted link chains which are easier on pavement than cleated or V bar types.
Tire Chains-snow chains-garden-lawn-TireChain.com
In your case, I'd go with the 2 link medium set.
The skid shoes and cutting edge on your snowblower can also mark up pavement. There are rubber attachments available to help with that. I've found that raising the blower off the ground slightly with the 3pt is the best approach. It adds more weight to the tractor and improves traction. Leaving a little snow behind also minimizes surface damage from the chains.
   / Snow handling: Turf Tires (R3) vs. Ag Tires (R1/R4) #20
I have a flat driveway so no slopes to worry about. I have no problems going anywhere with my front mount snowblower. I do not use any ballast or chains as I don't need them. The only time traction is an issue is when temperatures are around 0C/32F and you are working in wet snow. Chains aren't worth the hassle for the few times we have those conditions.
Every once in a while I still push snow with the front end loader. (Just so I don't forget how time consuming that is.) With no ballast or chains I can push snow hard enough to stall the engine.
When people in these forums say that you need ballast and chains to work in snow it makes me wonder what kind of conditions they have to warrant making those statements. I had chains for my 955. I never used them.
Edited to add that both the 955 and the 4410 are on turf tires. Both tractors also had wider front tires. Instead of 27x8.5x15 I installed a set of 26x12x12. Maybe the extra 7" of tire gives me a lot of extra traction. I don't know because I've never tried the 8.5's. If I feel ambitious maybe I'll try swapping them back on sometime.
M998 (A55852)
M998 (A55852)
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2017 BOBCAT T770 SKID STEER (A52709)
2017 BOBCAT T770...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58018)
2018 FREIGHTLINER...
