PapaBob
Hi Frankr2994, I too had issues with a Husqvarna Zero turn mower getting stuck and sliding on flat or near flat surfaces. My mower was a z4217. After several years of putting up with the Husqvarna and its short comings, the right side hydraulics failed and I had a legitimate reason to replace it. Bought a Kubota Z122EBR-48 and my problems were solved, holds the ground even on steep side hills and three years later has yet to miss a beat! Definitely the best decision I have made in a long time. Probably not the answer your looking for but worked for me.Hello all. I've researched this and I know it's been beaten but my issue is a little different. I just bought a husqvarna z242f. I only have a half acre so I don't need anything more or so I thought. My yard is pretty level. I have no wet spots and the only hill I have I've only done with a push mower. However I can't be on the slightest of grade with this husky and not slide or spin. Doing the long up and down runs in my yard the tractor wants to go to the left down hill. This is maybe 3 or 4 inches of slope per 4 foot. Hardly a hill. I find myself just skidding my right tire the whole way down the yard trying to go straight. Getting close to my pool made me question if I was going to drive it into the pool. Had to stop once and consider what direction I was going to try to make the front end not drop down and slam into the side of it. I also got stuck once trying to turn on complete flat ground. Wasn't trying to spin it just turn. Had to shut the deck off and back straight over my landscaping to get out of it. It's really unusable and I left ruts everywhere in my yard yesterday. Now this was my first time on it but I couldn't even practice doing a k turn or anything because it ending up taking 5 or more steps due to spinning to get pointed the right way. It has small 18x8.5-8 turfs on it. I thought that would be ok. The machine weighs just under 600lbs and I'm only 150lbs. Tires have 9 psi in them now. Any advice would be appreciated. I will never use this in the wet and I've kept my gt5000 to pull my cart and well do anything other than mow with.
P.S. I gave the Husqvarna to my least favorite brother-in-law so it was a win-win all way around!!!
