SLT1554 shut off, no restart
   / SLT1554 shut off, no restart #1
Cleveland1
My Cub Cadet shut itself off while I was turning. Now not even a click is offered when I turn the key. Any recommendations on what to check?
   / SLT1554 shut off, no restart #2
Check the seat switch. See if you left the PTO switch out. Brake peddle switch might not be working. My best guesses.
   / SLT1554 shut off, no restart #3
Tighten up the battery cables and check all other connections while your at it. From your description of it's abrupt stopping I would suspect a loose wire somewhere...just don't forget to switch off the PTO before before trying to restart.
   / SLT1554 shut off, no restart #4
Yep, we've seen reports of this before. A wire flops against something metallic on a turn. Check for broken insulation, loose wires, etc.
Joel
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A51039)
NEW 2025 Load...
2012 GALLEGOS TRAILER 130BBL VAC TRAILER (A50854)
2012 GALLEGOS...
Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K...
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
