Slow speed when tilting bucket on my Ford 4000 1972
   / Slow speed when tilting bucket on my Ford 4000 1972 #1
Alpagas
Quebec, Canada
Ford 4000
Hello all
After the first snowfall which left us with a good 8 inch of snow up here in Quebec ive been using my tractor a lot moree but its so painfully slow to empty the bucket that its no fun at all. Theres enough fluid in the diferential and to move the bucket up and down the speed is decent at best. Can someone point me to a solution or things i could check just to get a bit more speed.
   / Slow speed when tilting bucket on my Ford 4000 1972 #2
Has it always been this way or is it a new problem?
   / Slow speed when tilting bucket on my Ford 4000 1972 #3
Is the hydraulic fluid in the rear milky? if so, water is in the fluid and may be freezing up. I had the same issue on my 4000, and found the piston cylinder was bent. That's the last time I'll let anyone borrow the tractor. Had to have another cylinder fabbed.
   / Slow speed when tilting bucket on my Ford 4000 1972 #4
About a 70% chance the valve needs cleaned,,, spray with some PB Blaster.
A slow bucket when the arms still move at a decent speed almost always points to a valve spool that is not opening all the way.
   / Slow speed when tilting bucket on my Ford 4000 1972 #5
Check for play on the valvelever...valve not opening compleetly ?
2009 Lee-Boy 8510HD Conveyer Feed paver (A51039)
2009 Lee-Boy...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
UNUSED Black Outdoor Patio Fabric Screen Cover (A50860)
UNUSED Black...
London Fog 18-20 Mosquito Machine (A50860)
London Fog 18-20...
71056 (A49346)
71056 (A49346)
