Slope...what is safe?? Anyone here ever roll over?
   / Slope...what is safe?? Anyone here ever roll over? #62
Just an experience Ive had ( I wasn't the driver but a buddy was ) I worked for Park and Forestry, we were cutting a city park on the county line, there was a home that abutted to the park (no fences) and the older gent needed his lawn cut bad since its been raining all week and just stopped that morning, it wasn't a bad hill at all just a slight slope from his house towards the park. Now this was basically a side yard to the homeowner but the front was actually a 5' poured retaining wall to the street, so my buddy told him he could come up by the house and just swoop in near the retaining wall and cut all the way down for him and be done in like 10 minutes to help him out since we were already cutting. Well, on the 3rd pass and being the grass was soaked from the downpour earlier the tractors rear end slid out, and instead of going down towards the park it headed for the retaining wall, he couldn't get out of the slide, hit the lip of the wall and Ive never seen a tractor do a Dukes of Hazzard !!! When the back wheels hit, that's all she wrote, it tumbled head over heels, He went to jump as it hit the wall but caught his boot strings on the clutch, then jumped again with force to break them. he hit the pavement and rolled and so lucky he did as the tractor landed where he originally landed. All this while we all took off running towards him, and so lucky we did at the time, the tractor ended upright and kept going, 2 of us managed to get to it and stop it before hitting a van a lady has just parked and got out of and seen the whole thing. It was crazy. Now back to my buddy, he was ok except, a week before he got 30 stitches in his leg from a chainsaw accident so he was on light duty that day driving tractors since he couldn't climb trees...Yeah, he ripped every stitch. Just amazing the slightest slope can be so dangerous...just because its wet. Be careful and show every machine respect... even a push mower can get away from ya.
   / Slope...what is safe?? Anyone here ever roll over? #63
I was using my grapple to pull up privet bushes the other day. Very thick bushes that were 10-12' feet tall and had some 3&4" base stems. I grabbed a big mouthful of brush, with the roots being rooted just to the left of the grapple end on the left. When I picked up with the grapple, the roots and loader were all strong enough to cause my right side to pop up off the ground. I dropped the loader immediately and took another jab into the soil to break the root hold into the ground, but prior to that happening, I'd never considered that as a mechanism of tipping my tractor.
   / Slope...what is safe?? Anyone here ever roll over? #64
....Well, on the 3rd pass and being the grass was soaked from the downpour earlier the tractors rear end slid out, and instead of going down towards the park it headed for the retaining wall, he couldn't get out of the slide.....When the back wheels hit, that's all she wrote, it tumbled head over heels, He went to jump as it hit the wall but caught his boot strings on the clutch, then jumped again with force to break them. he hit the pavement and rolled and so lucky he did as the tractor landed where he originally landed....
I had a coach once tell me “Sometimes you make your own luck.”
   / Slope...what is safe?? Anyone here ever roll over? #65
Oh, yeah. A couple of days ago I basically did the same thing, and had the left rear wheel off of the ground for the exactly same reason. Part of my trouble was not stopping to take the blade off of the 3pt and putting on my ballast barrel. I had been grading the road. The blade might weigh 300 lbs if it was soaking wet, but I doubt it. Just not enough ballast= possibility of lifting rear of tractor. Fluid filled tires and all. I realized what was happening and was "taking it easy" knowing my rear end was light, but it happens pretty fast. No harm done, but a more novice operator could have panicked and flipped it I guess. Tractor with grapple on front and not enough ballast on the 3pt is a "whole different tractor".
   / Slope...what is safe?? Anyone here ever roll over? #66
I have a couple steep pastures to bush hog. It takes longer but I go up where not so steep, loop around going up that not too steep area. So downhill slowly, straight down, heavy side (bush hog) uphill.
I walked it beforehand removing any big rocks, tree stumps, filled pot holes.
Really bad areas I use a Cub Cadet zero turn mower. I learned how to shift my weight and PTO switch I can turn off instantly. I mow highest deck setting, if it gets out of control it's like riding a toboggan downhill. It's very safe. Better to go slow and easy. I never mow in morning (dew) or after a rain.
   / Slope...what is safe?? Anyone here ever roll over? #67
Hi,
I think the best mind set is to believe there is no safe slope for a tractor!.
Yep..that right there.
Charter member of the "rolled my tractor WITH a bush hog running and lived to tell about it" club. No rops. no seatbelt. My first little 22hp 1985 Yanmar, running a bush hog over a pile of tobacco stalks to chops them up....grade maybe 2-3%....nearly flat. Hit the pile at a run, back tire came up on the pile, and over it went. I fully believe bush hogs have a centrifugal effect that causes them hit a certain point, then 'gyro-scope' on over due to the rotating mass. It was 30+ years ago, I must have looked like Superman coming off the thing, because I rolled clear.
Broke the exhaust manifold because that model had a vertical muffler, little sheet metal damage. Used the truck to roll it back up, replaced manifold, started and ran it until I bought a NH Boomer in 1998.
   / Slope...what is safe?? Anyone here ever roll over? #68
I did something similar except that I was trying to lift the front of my BH so that I could put it on. I hooked a chain from the top link mount on the implement to the chain on my bucket and tried to raise it while standing on the ground; so I was using my left hand instead of my right. Instead of the bucket lifting, the left rear did. I tried to drop it, but because I was using my left hand instead of my right I went the wrong way... and of course the tractor was starting to lean on me. I quickly stopped what I was doing, walked a 10 foot circle, came back and got things on an even keel. Then I put my draw bar on and used the 3 point to raise it.
   / Slope...what is safe?? Anyone here ever roll over? #69
I did get to see what the pro's use to mow 45 degree inclines.. they have the tractor on level ground, and extend a boom mounted mower to the incline, and mow the grass!.. it seems the pro's don't want to play Kamikaze for some reason!..
   / Slope...what is safe?? Anyone here ever roll over? #70
Those are just the people who can afford big heavy powerful tractors and insanely priced implements.
Hose Reel (A55787)
Hose Reel (A55787)
New/Unused 2025 CFG QK18R Mini Excavator (A57453)
New/Unused 2025...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
JLG SCISSORLIFT (A52705)
JLG SCISSORLIFT...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
TANK MANIFOLD (A55745)
