Slipper clutch adjustment
   / Slipper clutch adjustment #1
caleb90
ih b414
My rural king tiller has a slipper clutch on it. Before using it i loosened it up and burnished the clutch surfaces. Tightened it back to where it was set and put a line on it with a paint pen. Tilling food plots today breaking fresh ground i hit some goobers. Enough to bog the tractor and make the tiller jump off the ground. I checked to see if it was slipping and it is. But im not sure if its slipping enough? This is my first slipper clutch so im not sure on how tight or loose they should be adjusted. Thanks
   / Slipper clutch adjustment #2
I mean, if it didnt come to a complete stop or break, I'd say it was good.
   / Slipper clutch adjustment #3
Your manual should have a procedure to adjust the slip clutch, it usually consists of measuring the length of the springs.
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
1267 (A50490)
1267 (A50490)
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2015 INTERNATIONAL...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
