RonMar
Elite Member
Per the schematic, closing any of the valves, including the variable flow control valve is just a nicety to keep from cycling the lift every time you dump the trailer.
Actually it is a requirement on the 200 series. There is a link from the 3PH lift arm to the control lever. If you don't close the speed reg valve, when you try and dump the trailer with the 3PH control, the arms will come up, and that lever will kick the control valve back into neutral before the dump trailer will move an inch...
