simplicity prestige lawntractor
   / simplicity prestige lawntractor #1
dahank
i just bought a prestige lawn tractor. we took tyhe deck off to get it in my trailer. i cleaned ther deck,and am now unable to maneuver the deck back under the mower. i cant believe this is kicking my butt. anyone have soem advice??? thanks::confused:
   / simplicity prestige lawntractor #2
I have a MF 2823, which is a Prestige clone. The deck comes off easy, but doesn't go back on nearly as simple. If you have a manual, follow the instructions to take the deck off, but in reverse, to the detail.
Turn the front wheels on the mower all the way to the left, then work the deck in from the right side. It takes some work, but when the front mounting hitch on the deck is just about touching the right front wheel, push the deck all the way back against the rear tire, and with the front edge of the front hitch on the ground, push the deck under until the hitch clears the tire. It's a close fit and you may have to work the front hitch a bit to get it to clear the tire. I hope that works for you, that's the best I can do from memory :)
Another tip: when you get to hooking the chains at the back on the deck to the lift, instead of trying to lift the edge of the deck and slip the chain over the lift hook, just use the deck height adjustment crank to raise the back on the deck by lowering the roller. That way you don't have to support the weight of the deck while fighting to slip the chain over the hook. The manual doesn't mention this, but doing it by the manual with the roller raised all the way up and the deck flat on the ground almost requires 3 hands.
   / simplicity prestige lawntractor #3
There is a video on the Simplicity web site that shows how to take it off..may be worth a look to give you some ideas.
   / simplicity prestige lawntractor #4
The deck on my Legacy is different, but also heavier! :( I've found that if I pivot the deck in it will go about half way, and is easier to pull the rest of the way through. The decks are a tight fit. +1 on using the rear roller to lift the deck when installing the chains. I think the newer Prestige have electric lift like my Legacy.
thanks!!! this helped a bunch...
2020 Bell B30E Off Road Dump Truck (A50860)
2020 Bell B30E Off...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
Okada Top 270 Hydraulic Breaker (A50860)
Okada Top 270...
2013 Ford Econoline E350 Passenger Van (A49461)
2013 Ford...
Lift station Pumps (A49461)
Lift station Pumps...
(6) Pipe Roller Stands (A50860)
(6) Pipe Roller...
