Side discharge to rear discharge?
   / Side discharge to rear discharge? #11
Less (almost none in my case) grass clippings left laying on top.
Doesn't seem to shoot debris as far, and if it does it goes out behind the tractor.
Easier to vary the mowing pattern to avoid ruts and, well, a pattern in the lawn.
   / Side discharge to rear discharge? #12
My rear discharge J-Bar finish mower is open all the way across the back of the mower. It lays the clippings down very evenly without any piling up. I'm happy with the way it cuts so far. I think it cost $1200 when I bought it, there are probably better finish mowers out there for the same money but I got it with the tractor and it was delivered to my door.
   / Side discharge to rear discharge? #13
I'd start by just covering up the discharge opening and see what you get. Likely, there will be a little bit of windrowing, but not enough to make a big deal.
   / Side discharge to rear discharge? #14
Just me, but before I went to all the trouble of trying to reinvent the wheel I'd check with local dealers and see what they would give you for trade-in on the side discharge model toward a rear dischage model.
UNUSED RAYTREE RMA42' HYD AUGER (A57193)
UNUSED RAYTREE...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2013 Ford F-150 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
CATERPILLAR 20" PIN ON BUCKET (A52707)
CATERPILLAR 20"...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55315)
Galvanized...
1992 Pine 53ft. T/A Dry Van Trailer (A55852)
1992 Pine 53ft...
