Sickle bar adjustment...getting hay to fall backwards
   / Sickle bar adjustment...getting hay to fall backwards #1
blaze 57
Bronze Member
Trying to figure out my new sickle mower. My old 350 Deere the hay would always fall backwards no matter how it was adjusted.. This Sitrex double action seems to be a little more finicky about this. Are you suppose to angle your bar upwards towards the sky to get it to fall backwards? thanks in advance
   / Sickle bar adjustment...getting hay to fall backwards #2
Try driving faster or increase knife speed
   / Sickle bar adjustment...getting hay to fall backwards #3
I believe you are. The bar should lean back about 10 degrees. This also helps the rock guards ride up over hidden objects.
   / Sickle bar adjustment...getting hay to fall backwards #4
Is the knife registered? Should never point below flush, if you have heavy thatch try tilting it up until it runs easy.
Yep! angled up must better. Thanks for the replies here!!
2017 and 2018 Stihl BG86 Hand Held Blower (A48083)
2017 and 2018...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
2003 John Deere 1600 Turbo Ride On Mower (A50860)
2003 John Deere...
2011 MAGNUM PRODUCTS LIGHT TOWER/WATER TANK TRAILER (A50854)
2011 MAGNUM...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A51039)
NEW 2025 Load...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
