   / Share Pics of People Hauling or Towing Something Wrong #12,072
I wanna drive the truck he痴 hauling! Man, what a toy that would be!
Get a job hauling for a big construction firm, or mining operation and you will drive them regularly. Fairly standard for moving big machinery.
   / Share Pics of People Hauling or Towing Something Wrong #12,074
Agreed. I do not recall any heavy-hauling tractor that has a lift (tag) axle behind the cab has two drive axles as well. Furthermore, IIRC, most all of the tag axles are not equipped with dual tires on each side, rather, only a single tire on each side.
BarnieTrk
   / Share Pics of People Hauling or Towing Something Wrong #12,075
BarnieTrk
I guess it depends what part of the country your from tri axle tractors are common around here with dual tires and super single tires
   / Share Pics of People Hauling or Towing Something Wrong #12,076
When I mentioned 'a single tire on each side' I meant single as in a standard tire, not a super single tire...
Tag axles ahead of the drive axles are fairly common around these parts (MICHIGAN) on heavy dump bed trucks. Most revolving drum truck mixers used for delivery of truck-mixed concrete are equipped with tag axles and some with a pusher axle. See diagram: Concrete Mixers - McNeilus
BarnieTrk
   / Share Pics of People Hauling or Towing Something Wrong #12,077
BarnieTrk
Depends on the axle rating higher with dual than a reg single , Most tri axles around here have a tag with super single tires, now all the new ones have steerable tag axle. I'm 76,000 gross on a tri axle dump and the 10wheel dump is 73,000 gross with 12-24 rubber
   / Share Pics of People Hauling or Towing Something Wrong #12,078
BarnieTrk
Depends on the truck and how it's setup.
Around here, there are a fair number that have super singles on the front with a 20,000# front axle (vs the standard 12,000# axle) and duals or super singles on the lift axle (which usually is a slightly smaller diameter tire than the drives).
Here is one in Denver: 27 KENWORTH T8B Day Cab Heavy Haul Truck | Ritchie Bros. Auctioneers
Aaron Z
   / Share Pics of People Hauling or Towing Something Wrong #12,079
For the first hour or so. Then there is not many more boring jobs. Just go around in the same circle all day. Every time I ended up in one I could not wait to get back into a highway truck. Preferably one like the one hauling it. Highway dump trucks just go around in bigger circles.
2021 John Deere 333G (A55272)
2021 John Deere...
(4) FORD 255/65-17 TIRES W/ 6 LUG RIMS (A58374)
(4) FORD 255/65-17...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
HOG COOKER MTD ON S/A TRAILER (A58374)
HOG COOKER MTD ON...
I-BEAM SPREADER BAR (A52708)
I-BEAM SPREADER...
New Landhonor Gas Water Pump (A59000)
New Landhonor Gas...
