   / Share Pics of People Hauling or Towing Something Wrong #6,651
Although I don't recall seeing any switch or sensor on any box on any dump truck I've driven. I think mechanics and owners would see it as just something else that would need fixing, or that would go bad at the wrong time.
A tee in the line to lift the dump cylinder with a pressure switch would take care of that without needing anything that would need to be adjusted or have dirt cleaned off of it.
Aaron Z
   / Share Pics of People Hauling or Towing Something Wrong #6,652
   / Share Pics of People Hauling or Towing Something Wrong #6,653
Both of my 1 Ton trucks that have PTOs can't go very fast with the PTO in. They bind up the transmission and won't shift over 2nd and make a squealing noise. I kinda doubt that's designed and just coincidence. How many of you recommending these switches have ever driven a dump truck? If you haven't noticed that the bed is up I'm sure you'll notice a little light that's blinking. Any buzzer that's loud enough to do any good is going to be annoying and get disabled.
   / Share Pics of People Hauling or Towing Something Wrong #6,654
Stick a rotating emergency light on top of the dash over toward the passenger side. It would be hard to ignore.
   / Share Pics of People Hauling or Towing Something Wrong #6,655
Haha every time I did a monthly pm on a dump truck (or crew truck) I would fix the reverse beeper. The next month when they came back for a pm, someone smashed it with a shovel again .......
   / Share Pics of People Hauling or Towing Something Wrong #6,656
Yeah, that would last as long as it took to disconnect it. Dark gray northwest days or late evening work would make something like that more a hindrance than any kind of help.
People make mistakes, I know I made a few over the years including failing to drop a truck or trailer box when I should have. Never left the job site that way, but I have gotten out of the truck to clean my reach and had to climb back in to drop the trailer box. I have seen a few major screwups by others, mostly pup trailers laying on their sides, and a couple of trucks tipped over. Mostly it was smaller mistakes, delivering the wrong product, tailgates popping open, and forgetting to set chains when doing a double spread, and so on. The point being everybody makes the occasional mistake. Usually the worst that comes from it is a bruised ego, but occasionally circumstances come together and result in something catastrophic.
   / Share Pics of People Hauling or Towing Something Wrong #6,657
Oops.
Found on WeldingWeb, origin unknown.
   / Share Pics of People Hauling or Towing Something Wrong #6,658
Glad there's an orange cone.
   / Share Pics of People Hauling or Towing Something Wrong #6,659
You have to wonder how that happened right on the edge of the road. Gust of wind?
   / Share Pics of People Hauling or Towing Something Wrong #6,660
One comment where I found that was: The illegible text above that phone number reads 'How's my driving?"
2019 PETERBUILT 579  DAYCAB (A58214)
2019 PETERBUILT...
Toro Ground Master 4000D (A56857)
Toro Ground Master...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
35176 (A55758)
35176 (A55758)
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56435)
2023 Kubota Z412KW...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
