Selective Control Valves (SCVs) Educate me please!
   / Selective Control Valves (SCVs) Educate me please! #11
If you look at my rear pic, youwill see the hoses plugged into the lower RH couplers. They can be plugged into either of the 3 pair that I have back there. 2 pair are controlled by the joystick, and the pair that they are using in the picture.
NOW, if you wanted to just raise/lower the loader, and had the rollback locked out, you could then plug the 3rd function lines into the couplers feeding the rollback cylinders and use this function to angle the blade. Keep in mind that rollback affects blade cutting/scraping ability.
Thanks for the info. I ordered my 3720 today. I ordered an adapter plate to mount the plow and I will try it with the curl feature locked out. If I find that it does not work well I can apparently control some lines with the MMM lift or the rear SCV and I could also just manually angle the rear blade.
PALLET OF FLUORESCENT LIGHT BULBS (A58374)
PALLET OF...
Toro (A56857)
Toro (A56857)
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2017 CATERPILLAR...
2016 CATERPILLAR 262D SKID STEER (A52709)
2016 CATERPILLAR...
