Scratch / Lift Start TIG Welding
   / Scratch / Lift Start TIG Welding #11
Lift and scratch start are different. Lift maintains a small voltage on the tip when the circuit is open. When you touch it to the work, it grounds the circuit and the machine detects that. When you lift it up and break the short circuit, it cranks the volts up to fire the arc (or something close to that). To my understanding it is supposed to be even better for tungsten contamination than high-freq, though I don't know why. I have only tried hi-freq briefly in a class but will probably get to do lift sometime down the road as my XMT304 has it but does not have high freq as is. Just need a torch, pedal and some argon...
Scratch start seems very much like striking an arc in stick welding.
   / Scratch / Lift Start TIG Welding #12
Yoiu can't always be working at a bench with a foot control (which is my fav.) Lift start can also be used with a hand amptrol torch hooked to a power supply that has 4T. Push the button and do your lift start, let go of the button and control the amperage. Hit the button again and it ramps down to zero. Same as a foot control if you have a quality power supply.Tungsten contaminaton is not good but you can get miles of tig welding out of a tungsten. Beats the snot out of old scratch start.
I am doing it with my Everlast Pa160. It works well, and the actual welding is the same. The starting takes some practice, not a big deal, and the stopping takes some practice (snap your wrist out to stop) Would HF start and a pedal to control the arc be nice?... you bet it would. Can you get done what you want done?.. You bet you can. Before all of that was invented everyone did TIG this way. Here is an example of something I repaired with Lift start Tig
http://www.tractorbynet.com/forums/welding/239186-am-i-stupid-crafty.html
James K0UA
Nice. Thanks for feedback, James!
You could be right James. I use the two names to describe the same thing
LOL,cursing helps, not realy it just makes you feel better :laughing: .....Mike
Probably my fault as I lumped the two together in my initial post. The lift start is not *supposed* to contaminate the tungsten. It is supposed to initiate a low energy arc and once the tungsten moves away from the metal it turns on the power like dstig1 stated. My bad.
Thanks for all of the comments. My appetite for trying TIG is definitely growing - just need to see if my wallet is willing to accommodate!
   / Scratch / Lift Start TIG Welding #15
I went down this road last year, and it does open up new vista's. Sure it is not like buying a nice dedicated TIG rig, but the most of the investment is the cylinder and regulator anyway, and you can reuse that if you ever do invest in the "real" TIG machine. It will allow you to work on smaller things with lots of control. Of course it takes lots of practice to do anything with it, but that is half the fun..be sure to get some tungsten's as you are going to be grinding a lot at first due to mistakes. I use lanthanated, (gold band) because it seems to be about as good as the thoriated (red band) but it is not radioactive. So you do not have to eat that nice radioactive dust. The actual tungsten (green band) is pretty much reserved now a days for high frequency AC welding on aluminum. In my opinion it is worth doing, and if you need some help let me know on getting the equipment going, If I can help I would be happy to.
James K0UA
   / Scratch / Lift Start TIG Welding #16
James K0UA
I never used the gold band stuff. Always the red for steel/stainless and green for aluminum.
Besides being less radioactive, are there any other benefits to the gold band??
   / Scratch / Lift Start TIG Welding #17
I remember weldingtipsandtricks did a video on it. He found that the 2% lan tungsten actually held up better then the red. Also, on inverter machines, just use the same tungsten for ac and dc. Only on the old school machines, did you need pure for ac. Edit: I wish you guys would stop talking about this... Making me want to spend money I dont have, for a tig rig I dont need.. :D
   / Scratch / Lift Start TIG Welding #18
None that I know of. It is just not radioactive, does not contain any Thorium. How important that really is and what real danger there is to the thoriated ones I don't really know. but there are precautions about breathing in the thorium dust when you grind them.
James K0UA
Good to know about the radiation aspect of it. As a beginner and hobbyist, the absolutely best weld will not be a priority for me as I am learning. I just hope not to blow any tungsten bits off and be able to sustain a steady arc!!
IF I get a starter TIG setup, I'll go with the lanthanated and see where that takes me.
I'm totally with deereman75. I shouldn't even be asking these questions given that I'm not sure when / if I'll be able to afford a stick welder, consumables, etc.
Thanks everyone for their input! Learning an awful lot.
   / Scratch / Lift Start TIG Welding #20
My startup cost was right at 350 bucks for everything. Torch, 125Cuft cylinder full of argon, regulator and the tungstens. Gloves and some TIG rod. I did buy the cylinder, so you could get by with a rental for less up front. Of course I already had the welder the Everlast PA160
James K0UA
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2002 Toyota Camry LE (A57148)
2002 Toyota Camry...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
Giyi Excavator Attachment Set (A57149)
Giyi Excavator...
1612 (A58375)
1612 (A58375)
2020 Ford F-150XLT (A57148)
2020 Ford F-150XLT...
