Scraper Blade Farm Pro 2425
   / Scraper Blade Farm Pro 2425 #1
Ed_B
Wisconsin
FarmPro 2425
Hey Folks! Happy Holidays!
I bought a six foot scraper blade (farm pro brand) for the 2425.
Problem: They didn't give me the two upright braces that go to the top point to the 3 pt hitch to the frame with the other two 3 pt attachments.The place I bought it from went belly up. I didn't need the blade, so I didn't put it together for a year, but now I do (I know should of unpacked it sooner).
Can anyone give me the measurements so I can make them? They are Two steel bars with holes on each end and the ends of both bars have an angle bent on them.
Thanks in advance.
   / Scraper Blade Farm Pro 2425 #2
I did some rough measuring on one we have in stock. use 2 25" long 2.25" flat bars. Put the two farthes holes on 23" centers. The top vertical peice is 6.5" long the bottom vertical piece is 3" long (by the 3 point pins). bend so the top and bottom are parrallell. If drill another hole at the top for the top link pin. hope this makes some sense and is of some help. you might be able to order form Homier but the parts book is not online yet for this implement.
Thanks Chip. I can figure it out. 1/4" stock you think?
Ed.
   / Scraper Blade Farm Pro 2425 #4
Yes, 1/4 inch would be fine, I didn't measure the thickness and I'm off today!
2020 John Deere 9520R Tractor (A50860)
2020 John Deere...
UNUSED Bubble Aluminum Foil Reflective Insulation (A50860)
UNUSED Bubble...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
