Saw won't stay running......Stihl MS290
   / Saw won't stay running......Stihl MS290 #21
If you tune it for when it's warm (as you should) it'll be lean when it's cold. That's ok as long as you let it warm up before you run it hard. Some guys will rev the snot out of the saw as soon as it starts.
   / Saw won't stay running......Stihl MS290 #22
I had an intermittent problem that I couldn’t figure out either. Saw ran fine but would lose power or even sometimes die while cutting. It ended up being the fuel supply line in the tank had a hole in it and when the gas was low it would start sucking air. Dealer figured it out and replaced the line. Works great
2011 Nissan Maxima Sedan (A53424)
2011 Nissan Maxima...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2008 Ford Taurus SEL Sedan (A55973)
2008 Ford Taurus...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
Eagle Weathervane (A55853)
Eagle Weathervane...
